jmf |
November 18, 2016 06:31 |
Using Run Time Selection : table pointer error at run time
Hi
I attempt to write a custom solid body motion solver. The external force management is massively inspired from "sixDoFRigidBodyMotion" (many thanks to the author), and uses the Run Time Selection mechanism.
The problem is that the RTS table pointer is not found and throw an error at run time.
Here's the skeleton of my code and the run error message.
I've been struggling with that bug for days.
I probably miss something big, too big to be seen ?
Dear RTS specialists, I would appreciate your help so much
Jean-Michel
/* solver.C
Info<< "Create bodyMotion" << nl << endl;
bodyMotion motion(mesh, bodyFluidDict);
/* bodyMotion.C
// * * * * * * * * * * Constructors * * * * * * * * *
Foam::bodyMotion::bodyMotion
fvMesh& mesh,
const dictionary& bodyFluidDict
// Add all the external actions
createAllExternActions(bodyFluidDict);
// * * * * * * * * * * Public * * * * * * * * * * *
void Foam::bodyMotion::createAllExternActions
if (bodyFluidDict.found("externalActions"))
const dictionary& actionsDict = bodyFluidDict.subDict("externalActions");
label iAction = 0;
externActionsPtrList_.setSize(actionsDict.size());
// Loop for reading each sub-sub-dictionary of actionsDict
forAllConstIter(IDLList<entry>, actionsDict, iter)
if (iter().isDict())
iAction++,
bodyExternActions::New
iter().keyword(),
iter().dict()
externActionsPtrList_.setSize(iAction);
/* bodyExternActionsNew.C
* Copy from sixDoFRigidBodyMotionRestraint::New()
Foam::autoPtr<Foam::bodyExternActions> Foam::bodyExternActions::New
const word& customName,
const dictionary& actionDict
const word actionType
actionDict.lookup("externalAction")
if (!dictionaryConstructorTablePtr_)
FatalErrorIn
"bodyExternActions::New(customName, actionDict)"
<< exit(FatalError);
///////////////////// FATAL ERROR /////////////////////////////////////////////
/* bodyExternActions.C
* Copy from sixDoFRigidBodyMotionRestraint.C
#include "bodyExternActions.H"
namespace Foam
defineTypeNameAndDebug(bodyExternActions, 0);
defineRunTimeSelectionTable(bodyExternActions, dictionary);
/* bodyExternActions.H:
* Copy from sixDoFRigidBodyMotionRestraint.H
// Forward declaration of classes
class bodyMotion;
class bodyExternActions
public:
//- Runtime type information
TypeName("bodyExternActions");
// Declare run-time constructor selection table
declareRunTimeSelectionTable
autoPtr,
bodyExternActions,
dictionary,
(const word& name, const dictionary& actionsDict),
(name, actionsDict)
// Constructors
//- Construct from the actionsDict dictionary
bodyExternActions
const word& name,
//- Construct and return a clone
virtual autoPtr<bodyExternActions> clone() const = 0;
// Selectors
//- Select constructed from the actionsDict dictionary
static autoPtr<bodyExternActions> New
const word& name,
/* bodySpring.C
* Copy from linearSpring.C
#include "bodySpring.H"
#include "addToRunTimeSelectionTable.H"
#include "bodyMotion.H"
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
namespace Foam
namespace bodyExternActions
defineTypeNameAndDebug(bodySpring, 0);
bodyExternActions,
bodySpring,
dictionary
/* bodyFluidDict
externalActions
spring1
externalAction bodySpring;
anchor ( 0.0 -0.0 0.0);
refAttachmentPt (-0.0 0.0 0.0);
stiffness 1000;
damping 1000;
restLength 0;
The run error message :
Create bodyMotion
> Creates new bodyExternActions:
spring1
anchor ( 0 -0 0 );
refAttachmentPt ( -0 0 0 );
stiffness 1000;
damping 1000;
restLength 0;
#0 Foam::error::printStack(Foam::Ostream&) at ~/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/printStack.C:219
#1 Foam::sigSegv::sigHandler(int) at ~/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/signals/sigSegv.C:56
#2 ? in "/lib64/libc.so.6"
#3 Foam::HashTable<Foam::autoPtr<Foam::bodyExternActions> (*)(Foam::word const&, Foam::dictionary const&), Foam::word, Foam::string::hash>::find(Foam::word const&) at ~/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/HashTable.C:143
#4 Foam::bodyExternActions::New(Foam::word const&, Foam::dictionary const&) at ~/OpenFOAM/OpenFOAM-2.4.0/src/bodyFluid/bodyMotion/bodyExternActionsNew.C:39
#5 Foam::bodyMotion::createAllExternActions(Foam::dictionary const&) at ~/OpenFOAM/OpenFOAM-2.4.0/src/bodyFluid/bodyMotion/bodyMotion.C:258 (discriminator 1)
#6 Foam::bodyMotion::bodyMotion(Foam::fvMesh&, Foam::dictionary const&) at ~/OpenFOAM/OpenFOAM-2.4.0/src/bodyFluid/bodyMotion/bodyMotion.C:73
#7 ? at ~/OpenFOAM/OpenFOAM-2.4.0/applications/solvers/multiphase/bodyWaveFoam/bodyWaveFoam.C:47
#8 __libc_start_main in "/lib64/libc.so.6"
#9 ? at /home/abuild/rpmbuild/BUILD/glibc-2.18/csu/../sysdeps/x86_64/start.S:125
