November 19, 2016, 12:42 |
Conductivity as a function of position!!
Rep Power: 10 |
Hi
I want to implement conductivity (K) of a material which is different in each coordinate direction. Solver : laplacianFoam K_x= 12 x K_y = 1. 5+0.3y K_z = 6z Any idea? Thanks in advance Last edited by Mohammad Jam; November 23, 2016 at 07:32. |
November 23, 2016, 07:33 |
Rep Power: 10 |
should i write special matrices?
November 23, 2016, 11:48 |
Tom Dylan
Rep Power: 10 |
If you are referring to the hydraulic conductivity, I guess you must implement anisotropy via a conductivity tensor. However I do not quite understand why your conductivity approach is distance dependent in each component.
November 23, 2016, 12:32 |
#4 | |
Rep Power: 10 |
Thanks for your kind reply. Yes i am referring to a nano fluid which has position dependent conductivity as i mentioned its relation. 1.How to implement anisotropy tensor with position dependent components OR fixed components? Any reference is welcome! thanks for your time. |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
Error in compiling new drag model | k.farnagh | OpenFOAM Programming & Development | 13 | May 21, 2016 03:08 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
