December 9, 2016, 11:16 |
File <time directory>/uniform/time
Thomas Oliveira
Rep Power: 12 |
Dear all,
The file <time directory>/uniform/time is written at every output time. From the source code of OpenFOAM 2.4.x, I understand this is done in Foam::Time::writeObject, line timeDict.regIOobject::writeObject(fmt, ver, cmp); What is this file used for? Can I choose not to write it without editing TimeIO.C and recompiling the library? Is there any problem if I remove this line? Best regards, Thomas |
October 29, 2018, 04:20 |
Daniel Witte
Rep Power: 14 |
Thomas,
Did you get any answer to your question? I am seeing the same in OF 2.3.x. I am using the interFoam applcation solver, which I have altered considerably. Before that, this never occured, now it does. Regards, Daniel |
October 29, 2018, 04:23 |
Thomas Oliveira
Rep Power: 12 |
Daniel,
I didn't get any answer, and I just let this file be written, even though I don't use it as far as I know. Thomas |
October 29, 2018, 04:48 |
Daniel Witte
Rep Power: 14 |
Thomas,
Thanks for the quick answer. I have filed a new post, maybe my problem is related: writeInterval wrong If you have an idea, I would be glad to hear from you again. Maybe your issue is related. Regards, Daniel |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
