January 11, 2017, 10:05 |
Gradient Schemes
Saurav Kumar
Rep Power: 9 |
Hi
i just started using OpenFoam and i am comparing Fluent and OpenFoam result. i have modified icoFoam (added energy equation) and trying to validate a paper result, they used Green-Gauss Node-Based method for gradient. Fluent has three option for gradient scheme (Green-Gauss Cell-Based, Green-Gauss Node-Based, Least Squares Cell-Based) and Green-Gauss Node-Based simulation gives more accurate result (nearly 5-10% more accurate as compare to Green-Gauss Cell based and Least Squares Cell based). in OpenFoam for gradient schemes we have Gauss linear cellLimited cellMDLimited edgeCellsLeastSquares faceLimited faceMDLimited fourthGauss cellLimited cellMDLimited edgeCellsLeastSquares faceLimited faceMDLimited fourth leastSquares pointCellsLeastSquares leastSquares pointCellsLeastSquares i tried with Gauss linear and got 10% error as compare to Fluent (Green-Gauss Node-Based). please suggest me which gradient scheme should i use to produce more accurate result? is there any alternate of Green-Gauss Node-Based gradient scheme in OpenFoam? Thank you |
February 11, 2017, 07:27 |
Saurav Kumar
Rep Power: 9 |
here is the plot of average Nu based on all these three gradient scheme but local Nu variation is same in all Scheme.
August 7, 2018, 23:24 |
Ruiyan Chen
Rep Power: 9 |
Have you tried leastSquares in OF? For my case, when using this option in Fluent the simulation runs smoothly but in OF there are divergence issues.
Fundamental questions about numerical schemes | Obad | OpenFOAM Running, Solving & CFD | 1 | May 10, 2021 10:40 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
gradient schemes | callumso | OpenFOAM Running, Solving & CFD | 7 | October 15, 2013 03:47 |
discretization schemes for Gradient | rayan24 | Fluent UDF and Scheme Programming | 1 | September 26, 2013 10:07 |
