Home > Forums > OpenFOAM Programming & Development
3D volume force term to axisymmetric!
Old   February 1, 2017, 18:30
Default 3D volume force term to axisymmetric!
OpenFoam
CFD-Lover is on a distinguished road
Hi all,
I have been reading the following code about introducing a volume source term in the simpleFoam to solve the flow over HAWT. Snipped of the code is as follows;
    if(debug >= 1) {
        Info << "Calculating volume force from actuator disk.\n";
    ReadGeometry(iMesh);
    scalar RadialDist2;
    vector LineTangent;
    vector CircumferentialDirection;
    vector TotalForce(0.0,0.0,0.0);
    scalar TotalTorque = 0.0;
    scalar DiskVolume = 0;
    //Loop over all cells and check if the cell center is in the actuator disk region
    for(label i = 0; i < iMesh.C().size(); i++) {
        if(PointIsInDisk(mPointStartCenterLine,mPointEndCenterLine,iMesh.C()[i],RadialDist2, LineTangent,CircumferentialDirection)) {
            if(debug >= 3) {
                Info << "Point: " << i << " is in the actuator disk. Coordinates: " << iMesh.C()[i] << "\n";
            vector axialForce = LineTangent*CalcAxialForce(sqrt(RadialDist2),mRho)/mRho;
            ioVolumeForce[i] += axialForce;
            //compute the total force added to the actuator disk, this is just for control
            TotalForce += axialForce*iMesh.V()[i];
            vector circForce = CircumferentialDirection*CalcCircForce(sqrt(RadialDist2),mRho)/mRho;
            ioVolumeForce[i] += circForce;
            TotalTorque += (CalcCircForce(sqrt(RadialDist2),mRho)/mRho)*sqrt(RadialDist2)*iMesh.V()[i];
            DiskVolume += iMesh.V()[i];
//    Check if a given point is located in the actuator disk region.
    vector VecLineTangent(iPointEndCenterLine - iPointStartCenterLine);
    scalar LineTangentLength = sqrt(VecLineTangent.x()*VecLineTangent.x() + VecLineTangent.y()*VecLineTangent.y() + VecLineTangent.z()*VecLineTangent.z());
    if(LineTangentLength != 0.0) {
        VecLineTangent /= LineTangentLength;
    else {
        Info << "Warning: The centerline tangent has zero length.\n";
        return false;
    oLineTangent = VecLineTangent;
    vector VecStartLineToPoint(iPoint - iPointStartCenterLine);
    scalar PointProjOnLine = VecStartLineToPoint & VecLineTangent;
    //Check if the point is inside the actuator disk in the axial direction
    if(!(PointProjOnLine >= 0.0 && PointProjOnLine <= LineTangentLength)) {
        return false;
    vector VecLineToPoint(VecStartLineToPoint - (VecLineTangent*PointProjOnLine));
    scalar RadialDist2 = VecLineToPoint.x()*VecLineToPoint.x() + VecLineToPoint.y()*VecLineToPoint.y() + VecLineToPoint.z()*VecLineToPoint.z();
    oDist2 = RadialDist2;
    oCircumferentialDirection = VecLineTangent ^ VecLineToPoint;
    oCircumferentialDirection /= mag(oCircumferentialDirection);
    //Check if the point is inside the actuator disk in the radial direction
    return(RadialDist2 <= mExtRadius*mExtRadius && RadialDist2 >= mIntRadius*mIntRadius);
    else {
        return false;
        return false;
    return(RadialDist2 < mIntRadius*mIntRadius);
//    Compute the force component in the axial direction. The force is computed from a simple equation resulting in a force
//    that varies with the radial distance.
//    If you have a better model of a rotor, comment the four lines below and add your own calculation of the axial force.
//    Do not forget to also change the calculation of the tangential force (CalcCircForce()) below.
    scalar axialForce = 0.0;
    scalar radiusScaled = (iRadialDist/mExtRadius - mIntRadius/mExtRadius)/(1.0 - mIntRadius/mExtRadius);
    scalar Ax = (105.0/8.0)*mThrust/(CalcDiskThickness()*mPI*(3.0*mIntRadius+4.0*mExtRadius)*(mExtRadius-mIntRadius));
    axialForce = Ax*radiusScaled*sqrt(1.0 - radiusScaled);
    if(debug >= 2) {
        Info << "Axial force: " << axialForce << "\n";
    return axialForce;
scalar actuatorDiskExplicitForce::CalcCircForce(const scalar &iRadialDist, const scalar &iRho) {
//    Compute the force component in the tangential direction. The force is computed from a simple equation resulting in a force
//    Change the four lines below if you have a better model.
    scalar tangentialForce = 0.0;
    scalar At = (105.0/8.0)*mTorque/(CalcDiskThickness()*mPI*mExtRadius*(mExtRadius-mIntRadius)*(3.0*mExtRadius+4.0*mIntRadius));
    tangentialForce = (At*radiusScaled*sqrt(1.0 - radiusScaled)/(radiusScaled*(1.0 - mIntRadius/mExtRadius) + mIntRadius/mExtRadius));
    if(debug >= 2) {
        Info << "Tangential force: " << tangentialForce << "\n";
    return tangentialForce;
The code is written to solve forces only in 3D but would like to rewrite to solve forces as axisymmetric. I don't really know what to change in the upper snipped code. The C++ file is also attached.
Many thanks,
CFD-Lover is offline   Reply With Quote
Thread Tools
Trackbacks are On
multiphaseEulerFoam high Courant number Frenk_T OpenFOAM 5 November 24, 2016 04:23
sHM layer process keeps getting killed MBttR OpenFOAM Native Meshers: snappyHexMesh and Others 4 August 15, 2016 03:21
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Modelling a force as a momentum source term - HELP Rick FLUENT 0 March 9, 2006 11:28
