February 8, 2017, 03:17 |
Change writeIntervall during simulation
Rep Power: 12 |
hi there,
i want to write out my fields in logarithmic timesteps. Since now, i´m restarting my simulation after a decade with an new writeIntervall. Is there a possiblity to change the writeIntervall during the simulation? Regards Christian |
February 9, 2017, 04:20 |
Joachim Herb
Rep Power: 21 |
The system/controlDict file is read after each time step (if you set runTimeModifiable to yes). So you can change it during the simulation and it will use the new settings for the next time step.
Of course this is not automatic. So perhaps, you can write a shell/Python script, which continuously reads the log file and modifies the controlDict, if a certain time step has been reached. |
February 10, 2017, 05:07 |
Rep Power: 10 |
You can automate the procedure using timeActivatedFileUpdate utility. It allows you to specify a number of files (controlDict in your case) that are read at specified time steps. So if you will not have too many changes in the writeInterval, you can simply create a few controlDict versions and specify in timeActivatedFileUpdate file at which time they should be used.
February 10, 2017, 05:10 |
Rep Power: 12 |
Thanks for your replys.
The solution by Zbynek seems to be very comfortable, so i´ll look for this one. |
Heat pipe simulation with phase change | mecman | OpenFOAM Running, Solving & CFD | 10 | May 8, 2020 03:42 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
Phase change from liquid to vapor in a nozzle | SebastianSchuster | CFX | 6 | September 28, 2015 22:02 |
restarting paused transient simulation using reactingFoam | JMDag2004 | OpenFOAM Running, Solving & CFD | 1 | August 10, 2015 10:15 |
How to change orientation of body in boat simulation?? | sanjay | STAR-CCM+ | 7 | January 15, 2012 00:24 |
