Error arising from Energy Equation
Old   February 15, 2017, 12:15
Default Error arising from Energy Equation
fouad abi
faab is on a distinguished road
Send a message via Skype™ to faab
Dear FOAMers,
I have posted this in the section dedicated to Running, Solving and CFD, however as I am not getting any answer I imagine maybe this was the wrong forum to address.
I am actually working on a compressible solver (density based) that I created using the pre-existing chtMultiRegionFoam solver. As stated in the title, I get (see hereunder) an error when solving for the following energy equation:
fvScalarMatrix EEqn
fvm::ddt(rho, he) + fvm::div(phi, he)
+ fvc::ddt(rho, K) + fvc::div(phi, K)
fvm::laplacian(kEff, T)
+ HS
HS is just a volumetric source term, and kEff is the effective conductivity.
he is the internal energy (I compute it using an external Fortran code)
while K is set as being: const volScalarField& K = 0.5 * (U & U);
#0 Foam::error: rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
at sigaction.c:?
#3 memcpy at interp.c:?
#4 std::string::append(std::string const&) in "/home/faabid/OpenFOAM/ThirdParty-2.3.0/platforms/linux64/gcc-4.8.1/lib64/libstdc++.so.6"
#5 std::basic_string<char, std::char_traits<char>, std::allocator<char> > std: perator+<char, std::char_traits<char>, std::allocator<char> >(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) at ~/OpenFOAM/ThirdParty-2.3.0/platforms/linux64/gcc-4.8.1/include/c++/4.8.1/bits/basic_string.h:2370
at ~/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fvcDiv.C:240 (discriminator 2)
at ~/OpenFOAM/OpenFOAM-2.3.0/applications/solvers/heatTransfer/CompressibleHeSolver/./fluid/EEqn.H:24 (discriminator 1)
#8 __libc_start_main at ??:?
at ??:?
Segmentation fault (core dumped)
Where fluid/EEqn.H:24 corresponds to:
I also remind that K is set to: const volScalarField& K = 0.5*magSqr(U);
Could anyone please help me ??
Thank you !!
faab is offline   Reply With Quote
Old   February 15, 2017, 15:46
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Why K is const reference (why not create just a copy of 0.5*(U & U) using constructor from tmp as volScalarField K(0.5*(U & U))? Are you sure, object it is referencing is not destroyed before construction of energy equation?
alexeym is offline   Reply With Quote
Old   February 16, 2017, 08:23
fouad abi
Hi Alexey,
First of all, thank you very much for your attention and help!
I did modified the way I construct and call K and you were right to point this out because the error seems now corrected. However, I am getting an error from the energy term "he" and it is the following:
FOAM FATAL ERROR:
    valueInternalCoeffs cannot be called for a calculatedFvPatchField
    on patch outsidewalls of field he in file "/home/faabid/OpenFOAM/faabid_cases/testCase/mine/CompressibleSolver/0/hell_channel/he"
    You are probably trying to solve for a field with a default boundary condition.
    From function calculatedFvPatchField<Type>::valueInternalCoeffs(const tmp<scalarField>&) const
    in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 154.
FOAM exiting
The "he" term is defined in my code as:
volScalarField& he = heFluids[i];
heFluids.set
            i,
            new volScalarField
                IOobject
                    "he",
                    runTime.timeName(),
                    fluidRegions[i],
                    IOobject::MUST_READ,
                    IOobject::AUTO_WRITE
                fluidRegions[i],
                dimensionedScalar
                    "he",
                    dimensionSet(1,2,-2,0,0,0,0),
                    scalar(1990.4)
And computed using an external Fortran code, from the thermodynamic properties rho, T and P at every time step. Also in the fvSchemes dictionnary I defined:
divSchemes
    default         none;
    div(phi,U)      Gauss upwind;
    div(rho,he)      Gauss upwind;
    div(phi,he)      Gauss upwind;
    //div((p*U))        Gauss linear;
    div(phi,(0.5*magSqr(U)))      Gauss linear;
    grad(T)            Gauss linear;
And he is itself defined in the initial folder 0/ as:
dimensions      [1 2 -2 0 0 0 0];
internalField   uniform 1990.4;
boundaryField
    FrontAndBack
        type            empty;
    outsidewalls
        type            gradientEnergy;
        gradient        uniform 0;
    hell_channel_to_solid2
        type            mixedEnergy;
        refValue        uniform 0;
        refGradient     uniform 0;
        valueFraction   uniform 0;
        value           $internalField;
    hell_channel_to_solid1
        type            mixedEnergy;
        refValue        uniform 0;
Would you or anyone have a suggestion to get past this error ?
Once again thank you for your time and support, it's much appreciated!
Old   February 16, 2017, 08:35
Alexey Matveichev
Default constructor of volScalarField (which is just typedef over GeometricField, http://cpp.openfoam.org/v4/a00931.ht...0d8f8a5fec0dc8) sets calculated type for all boundary conditions, hence the error. The easies ways if to add to your constructor "zeroGradient", so he field has zero gradient BCs everywhere.
heFluids.set(
  i,
  new volScalarField(
    IOobject("he", runTime.timeName(), fluidRegions[i], IOobject::MUST_READ,
             IOobject::AUTO_WRITE),
    fluidRegions[i],
    dimensionedScalar("he", dimEnergy, 1990.4),
    "zeroGradient"));
Strictly speaking, you need to set real BCs for he, which correspond to your problem.
Old   February 16, 2017, 09:36
fouad abi
Hi Alexey,
I understand, I did not know about that, thanks a lot for the tip. I will try that as soon as I get my hands back on the code and will keep you posted. Thanks again for your valuable help !
Old   February 17, 2017, 05:27
fouad abi
Hi again,
The solution you provided did the job, now I've got to figure out why the solution for "he" diverges and makes the solver crash after a few time steps. But you were of great help, thanks a lot for everything Alexey !
Faab
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
Error in computing Energy equation faab OpenFOAM Running, Solving & CFD 0 February 3, 2017 13:04
error message cuteapathy CFX 14 March 20, 2012 06:45
energy equation in rhoCentralFoam nakul OpenFOAM 0 October 10, 2010 15:07
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 06:06
