saimat |
February 27, 2017 11:52 |
Implementing variable Diffusion Coefficient
Dear foamers,
I am trying to expand the functionality of twoLiquidMixingFoam so that it can handle Diffusion coefficients which depend on the volume fraction of one of the liquids:
in which and are positive constants. Given this dependency and assuming (neglecting advection) the advection-diffusion-equation looks as follows:
The first term is already implemented in twoLiquidMixingFoam/alphaDiffusionEqn.H, whereas the second one is missing:
fvScalarMatrix alpha1Eqn
fvm::ddt(alpha1)
- fvc::ddt(alpha1)
- fvm::laplacian
volScalarField("Dab", Dab + alphatab*turbulence->nut()),
alpha1
I tried to implement it in two ways and tried to validate the resulting solver in a simple 1-D configuration initially containing a jump from alpha1=0 to alpha1=1.
The first try was taking the values from the last timestep:
Dab = C1*Foam::exp(C2*alpha1);
volScalarField Sc = fvc::grad(Dab) & fvc::grad(alpha1);
fvm::ddt(alpha1)
- fvc::ddt(alpha1)
- fvm::laplacian
alpha1
Sc
The results showed a growing total volume fraction of alpha1, meaning a production of phase 1. Additionally, the alpha1 values exceeded 1.
Starting time loop
Courant Number mean: 0 max: 0
Interface Courant Number mean: 0 max: 0
Z number max: 0
deltaT = 0.0119976
Time = 0.0119976
MULES: Solving for alpha1
Phase-1 volume fraction = 0.027 Min(alpha1) = 0 Max(alpha1) = 1
ExecutionTime = 0.54 s ClockTime = 0 s
Z number max: 3382.27
deltaT = 7.0944e-06
Time = 0.0120047
Phase-1 volume fraction = 0.0681488 Min(alpha1) = 0 Max(alpha1) = 15.1184
Both of these effects are dependent on the grid resolution. Nevertheless, even with poor resolution, this non-physical, non-conservative behavour persists.
The second way I tried to implement the additional term was by using Picard's method ( https://www.cfd-online.com/Wiki/Sour...inearization):
volScalarField Sp = C1*C2*C2*Foam::exp(C2*alpha1) * fvc::grad(alpha1) & fvc::grad(alpha1);
volScalarField Sc = (C1*C2*Foam::exp(C2*alpha1) * fvc::grad(alpha1) & fvc::grad(alpha1))*(1-C2*alpha1);
fvm::ddt(alpha1)
- fvc::ddt(alpha1)
- fvm::laplacian
alpha1
fvm::Sp(Sp, alpha1) + Sc
In that case I was not able to get a stable calculation/converging solution. The solver diverged after some timesteps.
Does anyone have an Idea how to improve the implementation? I would be very grateful if anyone could give me a hint how to solve the problem.
