Shear stress boundary condition at free surface |
September 2, 2019, 06:34 |
Rep Power: 7 |
Hello everyone,
I am simulating a free rising bubble in a viscoelastic fluid with a moving mesh solver. I implemented the viscoelastic stress term in the momentum equation aswell as the equations to calculate velocity and pressure boundary conditions at the bubble interface. Since the newtonian stress can be directly expressed with viscosities and velocities, this leaves the just a pressure and a velocity field in the original solver. With boundary conditions at the free surface as follows: Inside velocity: fixed value pressure: fixed gradient Outside velocity: fixed gradient pressure: fixed value While the viscoelastic stress can't be calculated directly from the velocity a PDE is solved returning a tau field for which I now have to find boundary conditions for. What would be boundary conditions for my tau field at free surface? Why were those boundary conditions for velocity and pressure chosen? Is it done similar to inlet and outlet boundary conditions of a pipe for numerical stability? v_inlet=fixedValue, p_inlet=zeroGrad and v_outlet=zeroGrad, p_outlet=fixedValue. Would I chose the boundary conditions similar to the velocity boundary conditions since the stress is a function of the velocity? The fixed gradient boundary condition for the velocity is applied as with being the normal vector on the free surface. If I would apply the same boundary condition for the shear stress this would be where I have to find the gradient of a tensorField, which is not defined in OpenFOAM. I was experimenting with snGrad() but im not sure, if it does what i request. I am working with foam extend 4.0. Many thanks for your help, I hope you understand my problem. Paul |
stress free boundary condition | Ari | FLUENT | 7 | December 20, 2023 06:00 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
How to implement shear stress boundary condition? | Zubair959 | Main CFD Forum | 0 | June 12, 2013 22:04 |
how to set up a wall boundary condition according to calculated wall shear stress? | gameoverli | OpenFOAM Pre-Processing | 1 | May 21, 2009 08:28 |
Shear Stress Boundary Condition | Prabhas | FLUENT | 0 | December 5, 2006 00:53 |
