What is the difference of the codes under src and applications? |
March 1, 2017, 16:52 |
Rep Power: 9 |
Hi there,
I'm starting coding with OpenFOAM and I'm confused that there are some files holding same names and contents under OpenFOAM-4.1/src and OpenFOAM-4.1/applications For example, we have /OpenFOAM-4.1/src/mesh/blockMesh/blockMesh/blockMesh.C and /OpenFOAM-4.1/applications/utilities/mesh/generation/blockMesh/blockMesh.C My question is, why do we need the same file in different folders? |
March 2, 2017, 02:53 |
Kevin van As
Rep Power: 20 |
If you'd open those files, you'll see that they are not the same.
src: All OpenFoam libraries' sources. This code doesn't do anything on its own: it needs an executable to require them in order to be executed. applications: All executables, like solvers and pre-/postprocessing utilities. These executables typically use (a lot of) source code from OpenFoam's libraries by linking the libraries (see: Make/options that resides in every solver directory etc.). In the case of blockMesh,
March 2, 2017, 14:30 |
#3 | |
Rep Power: 9 |
Thanks a lot! |
Is it safe to change owner of src to root? | chrisb2244 | OpenFOAM Programming & Development | 2 | February 20, 2014 06:59 |
