Adding extra mapped fields to kinematicSingleLayer |
March 20, 2017, 09:26 |
Rep Power: 9 |
hey,
I'm using the reactingParcelFilmFoam and want to implement the neglected shear force at the gas-liquid interface. My plan is to access the calculated shearstress-tensor at the wall via the turbulence model (as done in the wallShearStress-function object). The problem is, I can't access this data in the liquid layer, because it's an extra Region. So I want to add this information to an extra field in the kinematicSingleLayer. Then afterwards I can implement an extra force-model (e.g like the termocapillarityForce) for the shear stress. That should be possible, right? So I added to the constructor of kinematicSingleLayer.C an extra field where I want to write the shearStress from the turbulence model- Code:
... , devRhoReff_ ( IOobject ( "devRhoReff", //maybe wrong, but error stays same for e.g 'Uf' time().timeName(), regionMesh(), IOobject::NO_READ, IOobject::NO_WRITE ) ), ... Code:
... inline volSymmTensorField& devRhoReff(); ... volSymmTensorField devRhoReff_; ... virtual const volSymmTensorField& devRhoReff() const; ... Code:
... inline volSymmTensorField& kinematicSingleLayer::devRhoReff() { return devRhoReff_; } ... inline const volSymmTensorField& kinematicSingleLayer::devRhoReff() const { return devRhoReff_; } ... Code:
... In constructor ‘Foam::regionModels::surfaceFilmModels::kinematicSingleLayer::kinematicSingleLayer(const Foam::word&, const Foam::fvMesh&, const dimensionedVector&, const Foam::word&, bool)’: kinematicSingleLayer/kinematicSingleLayer.C:867:24: error: no matching function for call to ‘Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject)’ addedMassTotal_(0.0) ^ kinematicSingleLayer/kinematicSingleLayer.C:867:24: note: candidates are: In file included from /home/fschilling/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude/GeometricField.H:651:0, from /home/xxx/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude/GeometricScalarField.H:38, from /home/xxx/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude/GeometricFields.H:34, from /home/xxx/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude/volFields.H:37, from /home/xxx/OpenFOAM/OpenFOAM-4.1/src/regionModels/regionModel/lnInclude/regionModel.H:42, from /home/xxx/OpenFOAM/OpenFOAM-4.1/src/regionModels/regionModel/lnInclude/singleLayerRegion.H:38, from lnInclude/surfaceFilmModel.H:40, from kinematicSingleLayer/kinematicSingleLayer.H:38, from kinematicSingleLayer/kinematicSingleLayer.C:26: /home/fschilling/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude/GeometricField.C:663:1: note: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&, const wordList&, const wordList&) [with Type = Foam::SymmTensor<double>; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh; Foam::wordList = Foam::List<Foam::word>] Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField ^ ... Thanks! |
December 4, 2018, 06:28 |
Martin Novák
Rep Power: 13 |
Hi.
I find this interesting. Have you manged to add the shear force in? Thanks Martin |
conjugateHeatFoam + interFoam | farhagim | OpenFOAM Programming & Development | 15 | July 19, 2016 07:55 |
chtMultiRegionSimpleFoam | samiam1000 | OpenFOAM Running, Solving & CFD | 39 | March 31, 2016 08:43 |
Boundary Condition For Mapped Fields in OpenFOAM | Alhasan | OpenFOAM Running, Solving & CFD | 32 | January 11, 2014 17:51 |
a reconstructPar issue | immortality | OpenFOAM Post-Processing | 8 | June 16, 2013 11:25 |
an odd(at least for me!) reconstructPar error on a field | immortality | OpenFOAM Running, Solving & CFD | 3 | June 3, 2013 22:36 |
