March 20, 2017, 12:48 |
Code compiling in OF240 but not in OF4X
Lisandro Maders
I programmed a code that is compiling fine in OpenFOAM 2.4.0. However, I tried to compile it in blue-cfd , which is based on OpenFOAM 4.x and I got an error, which is described as follows. I compiled the native OpenFOAM 4.x in my Ubuntu in order to test and I got the same error, so the error is not related to blue-cfd or Windows. The line which the error occurs is in bold red. Here is only a piece of the code: Code:
Foam::tmp<Foam::volVectorField> Foam::readSourceData::assignSourceValues ( const fvMesh& mesh ) { tmp<volVectorField> tsource ( new volVectorField ( IOobject ( "source", mesh.time().timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), mesh, dimensionedVector("zero", dimensionSet(1,-2,-2,0,0,0,0),Foam::vector(0,0,0)) ) ); volVectorField& source = tsource(); forAll(source,celli) { .... .... Lot of stuff ..... .... source[celli] = Foam::vector(sourceData_[a][4],sourceData_[a][5],sourceData_[a][6]); } ... .... ...... Code:
readSourceData/readSourceData.C: In member function ‘Foam::tmp<Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> > Foam::readSourceData::assignSourceValues(const Foam::fvMesh&)’: readSourceData/readSourceData.C:180:38: error: invalid initialization of reference of type ‘Foam::volVectorField& {aka Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&}’ from expression of type ‘const Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>’ volVectorField& source = tsource(); ^ make: *** [Make/linux64GccDPInt64Opt/./readSourceData/readSourceData.o] Error 1 Code:
tsource(); Code:
volVectorField& source Any one that have any idea I would appreciate this. |
March 20, 2017, 16:17 |
Sergei
Rep Power: 21 |
volVectorField& source = tsource(); Code:
volVectorField& source = tsource.ref(); |
March 21, 2017, 13:04 |
Lisandro Maders
I am struggling to download OF4.x in another machine.. As soon as I do this I will check your suggestion and see if it works.
But anyway, my C++ is not the best in the world, but as far as I have read, and I quote now, "for tmp objects, non-const access uses a ref() function rather than the () dereferencing operator.". This was changed from OpenFOAM 4.0 version on, that's why it was compiling fine in OpenFOAM 2.4 version and not in OF4.X versions.. It will probably work now.. I let you know as soon as I verify it. Edit: Yes, it worked!! Thanks a lot! Lisandro Maders Last edited by Lisandro Maders; March 21, 2017 at 15:41. Reason: Tried the suggestion and it worked! |
blue-cfd, compilation error, of4x |
[Other] Comparing OpenFOAM to another code: advice on dealing with meshes? | SFr | OpenFOAM Meshing & Mesh Conversion | 1 | June 11, 2016 12:02 |
something wrong when compiling udf, however the code is correct when interpreting | richard ben | Fluent UDF and Scheme Programming | 7 | May 11, 2013 07:36 |
problem with compiling the source code | michel1988 | OpenFOAM Installation | 1 | April 17, 2013 17:19 |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 12:30 |
Small 3-D code | Zdravko Stojanovic | Main CFD Forum | 2 | July 19, 2010 10:11 |
