Including PETSc in an OF solver
Old   March 25, 2017, 08:59
Default Including PETSc in an OF solver
Basel Abu-sinni
BaselAS is on a distinguished road
Hello friends,
I'd like to include PETSc's headers in my solver but I can't figure out how to make it compile.
A PETSc program's makefile is as follows:
include ${PETSC_DIR}/lib/petsc/conf/variables
include ${PETSC_DIR}/lib/petsc/conf/rules
all: src/LinearSystemSolver.o chkopts
	-${CLINKER} -o LinearSystemSolver src/LinearSystemSolver.o  ${PETSC_KSP_LIB}
	${RM} LinearSystemSolver.o
And OF's solver's makefile is, as you may already know, split into two files('options' and 'files') under a directory called 'Make':
'options':
EXE_INC = \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude
EXE_LIBS = 	-lfiniteVolume \
			-lmeshTools
'files':
myLaplacianFoam.C
EXE = App/myLaplacianFoam
How am I supposed to edit 'options' and 'files' to make it work?
I appreciate your time and thanks in advance!
Basel
BaselAS is offline   Reply With Quote
Old   April 1, 2019, 21:28
Vu
DoQuocVu is on a distinguished road
Hi Basel,
I am trying to do the same thing. Have you been able to link petsc with your solver?
DoQuocVu is offline   Reply With Quote
Old   April 1, 2019, 22:41
Vu
For someone who might need the answer, I was able to link the icoFoam solver with petsc by doing the following steps:
Note: I am using petsc-3.4.5 and it is installed in my /home directory.
1. Create a shared library of petsc by invoking the following command from any directory in the PETSc source
make BOPT=O shared
This command will generate libpetsc.so in the folder arch-linux-cxx-opt/lib and it will be included into Make/options.
2. Include petsc.h into icoFoam.C
#include "petsc.h"
3. Change the Make/options to:
PETSC_DIR=$(HOME)/petsc/petsc-3.4.5
EXE_INC = \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(PETSC_DIR)/include \
    -I$(PETSC_DIR)/include/mpiuni \
    -I$(PETSC_DIR)/$(PETSC_ARCH)/include
EXE_LIBS = \
    -lfiniteVolume \
    -lmeshTools \
    -L$(PETSC_DIR)/$(PETSC_ARCH)/lib -lpetsc
4. Compile:
export PETSC_ARCH=arch-linux-cxx-opt
wmake
I have no idea why putting the line PETSC_ARCH=arch-linux-cxx-opt into Make/options does not work. That's why I have to define the PETSC_ARCH variable explicitly and then wmake.
Hope this can helps
Old   April 10, 2019, 04:04
Vu
I am sorry, eventhough the solver was successfully compiled, it does not work.
The error is that libpetsc.so could not be found, even though it is still exist in my $PETSC_ARCH/lib directory:
icoPetscFoam: error while loading shared libraries: libpetsc.so: cannot open shared object file: No such file or directory
I have been struggling with this problem for weeks but I have not been able to find a clue to fix it. I would appreciate any suggestion to help me solve this.
Old   April 10, 2019, 20:24
Vu
Problem solved!
Just need to define the LD_LIBRARY_PATH environmental variable in $HOME/.bashrc
echo "export LD_LIBRARY_PATH=\$PETSC_DIR/\$PETSC_ARCH/lib">>$HOME/.bashrc
Radiation Modeling Using Discrete Ordinates Method and Parallel Solver malicemethods FLUENT 3 May 25, 2018 14:25
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
Parallel solver for Poisson equation using PETSc JackNapier Main CFD Forum 0 July 5, 2012 16:53
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
