How to get the point coordinates in OpenFOAM?
Old   March 30, 2017, 21:38
Default How to get the point coordinates in OpenFOAM?
Xu Yiming
ousoweak is on a distinguished road
hi all
I am new to OpenFOAM programming and I want to get the distance between a specific point on the wall and the boundary-line of the wall. Related operations should be conducted in nutUspalding Wall Function file.
To achieve this, it is obviously that (1) I should get the point coordinate (x,y,z) and in .C file (2) get the 3D coordinate of the boundary-line. But I don’t know how to access them in openfoam?
Can anyone help me ? thanks.
Attached file is the sketch of the problem.
Yiming
The nutUspalding Wall Function file are list as fellow:
namespace Foam
// * * * * * * * * * * * * Protected Member Functions * * * * * * * * * * * //
tmp<scalarField> nutUSpaldingWallFunctionFvPatchScalarField::calcNu t() const
const label patchi = patch().index();
const turbulenceModel& turbModel = db().lookupObject<turbulenceModel>
IOobject::groupName
turbulenceModel:ropertiesName,
internalField().group()
const fvPatchVectorField& Uw = turbModel.U().boundaryField()[patchi];
const scalarField magGradU(mag(Uw.snGrad()));
const tmp<scalarField> tnuw = turbModel.nu(patchi);
const scalarField& nuw = tnuw();
return max
scalar(0),
sqr(calcUTau(magGradU))/(magGradU + ROOTVSMALL) - nuw
tmp<scalarField> nutUSpaldingWallFunctionFvPatchScalarField::calcUT au
const scalarField& magGradU
) const
IOobject::groupName
const scalarField& y = turbModel.y()[patchi];
const scalarField magUp(mag(Uw.patchInternalField() - Uw));
const scalarField& nutw = *this;
tmp<scalarField> tuTau(new scalarField(patch().size(), 0.0));
scalarField& uTau = tuTau.ref();
forAll(uTau, facei)
scalar ut = sqrt((nutw[facei] + nuw[facei])*magGradU[facei]);
if (ut > ROOTVSMALL)
int iter = 0;
scalar err = GREAT;
do
scalar kUu = min(kappa_*magUp[facei]/ut, 50);
scalar fkUu = exp(kUu) - 1 - kUu*(1 + 0.5*kUu);
scalar f =
- ut*y[facei]/nuw[facei]
+ magUp[facei]/ut
+ 1/(E_*exp(kappa_*0))*(fkUu - 1.0/6.0*kUu*sqr(kUu));
scalar df =
y[facei]/nuw[facei]
+ magUp[facei]/sqr(ut)
+ 1/(E_*exp(kappa_*0))*kUu*fkUu/ut;
scalar uTauNew = ut + f/df;
err = mag((ut - uTauNew)/ut);
ut = uTauNew;
} while (ut > ROOTVSMALL && err > 0.01 && ++iter < 10);
uTau[facei] = max(0.0, ut);
return tuTau;
ousoweak is offline   Reply With Quote
Old   April 4, 2017, 07:04
Jibran
Jibran is on a distinguished road
Originally Posted by ousoweak View Post
hi all
Yiming
namespace Foam
IOobject::groupName
return max
scalar(0),
) const
IOobject::groupName
forAll(uTau, facei)
int iter = 0;
scalar err = GREAT;
do
scalar f =
+ magUp[facei]/ut
scalar df =
y[facei]/nuw[facei]
ut = uTauNew;
return tuTau;
The nodal coordinates can be obtained as
mesh.points()[nodeID]
and boundary face coordinates as
Cf.boundaryField()[patchID][facei]
Here the 'patchID' is the ID associated to a particular boundary and 'facei' is the local face numbering within that boundary.
Jibran Haider
https://jibranhaider.com/
Jibran is offline   Reply With Quote
Old   April 9, 2017, 11:45
Xu Yiming
Originally Posted by Jibran View Post
Thanks so much for your reply.
With your help,I can get the nodal coordinates by using the code "turbModel.mesh().points()[nodeID]" successfully.
But I still don't know how to get the "nodeID" of the current calculation grid point in the USpalding wall function.Can you help me?
Thank you again.
Yiming
Old   April 10, 2017, 06:59
Jibran
Thank you again.
Yiming
You are welcome. A solution could be to have nested loops on boundary patches, patch faces and then the nodes attached to the faces. I haven't tested this but something like this should work!
forAll(mesh.boundary(), patchID)
    const word& patchName = mesh.boundary()[patchID].name();
    forAll (mesh.boundary()[patchID],facei)
         const label& faceID = mesh.boundaryMesh()[patchID].start() + facei;
         forAll (mesh.faces()[faceID], nodei)
               const label& nodeID = mesh.faces()[faceID][nodei];
Jibran Haider
Old   April 16, 2017, 22:43
Xu Yiming
Thank you so much!!!
The code what you have written was exactly the right solution!
the code I used to get point coordinate in the wall function is:
vector pointX(0,0,0);
const label& faceID = patch().boundaryMesh()[patchi].start() + facei;
 forAll (turbModel.mesh().faces()[faceID], nodei)
               const label& nodeID = turbModel.mesh().faces()[faceID][nodei];
pointX=turbModel.mesh().points()[nodeID];
Thank you again~
Yiming
Old   April 18, 2017, 04:07
Jibran
Thank you again~
Yiming
You are most welcome. I am glad that I could be of help. Enjoy!
Jibran Haider
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 06:15
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 11:50
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
