blttkgl |
April 6, 2017 07:35 |
Add curvature term to bEqn?
Hey all,
I am trying to modify bEqn.H file inside the XiFoam solver to add curvature effect kappa into the b scalar calculation.
the term I am trying to add is the following:
which can be written as :
I want to use the already calculated b and n fields inside the bEqn.H from the following lines:
volVectorField n("n", fvc::grad(b));
volScalarField mgb(mag(n));
dimensionedScalar dMgb = 1.0e-3*
(b*c*mgb)().weightedAverage(mesh.V())
/((b*c)().weightedAverage(mesh.V()) + SMALL)
+ dimensionedScalar("ddMgb", mgb.dimensions(), SMALL);
mgb += dMgb;
surfaceVectorField SfHat(mesh.Sf()/mesh.magSf());
surfaceVectorField nfVec(fvc::interpolate(n));
nfVec += SfHat*(fvc::snGrad(b) - (SfHat & nfVec));
nfVec /= (mag(nfVec) + dMgb);
surfaceScalarField nf((mesh.Sf() & nfVec));
n /= mgb;
#include "StCorr.H"
// Calculate turbulent flame speed flux
surfaceScalarField phiSt("phiSt", fvc::interpolate(rhou*StCorr*Su*Xi)*nf);
scalar StCoNum = max
mesh.surfaceInterpolation::deltaCoeffs()
*mag(phiSt)/(fvc::interpolate(rho)*mesh.magSf())
).value()*runTime.deltaTValue();
Info<< "Max St-Courant Number = " << StCoNum << endl;
// Create b equation
fvScalarMatrix bEqn
fvm::ddt(rho, b)
+ mvConvection->fvmDiv(phi, b)
+ fvm::div(phiSt, b)
- fvm::Sp(fvc::div(phiSt), b)
- fvm::laplacian(turbulence->alphaEff(), b)
fvOptions(rho, b)
can I directly go with fvm::div(n) and add it? I am new to OpenFoam programming so any help is appreciated.
-Bulut
