April 6, 2017, 07:44 |
Generating sample points
Ebrahim
Rep Power: 16 |
I need to generate a number of sample points inside a grid cell. Is there any utility / function in OpenFOAM which can do this for me? Or do you have any experience in this matter? Thanks, Ebrahim |
April 20, 2017, 10:01 |
Sampling data
Max
Rep Power: 9 |
Dear Ebrahim,
you can easily sample along lines, surfaces or boundaries with the sample utility. sample is executed by running "sample" in terminal. I leave below a link describing how sample works and anotherone to a "sampleDict" file. http://www.openfoam.com/documentatio...ide/sample.php https://github.com/OpenFOAM/OpenFOAM...ple/sampleDict Good luck |
April 22, 2022, 12:10 |
Rep Power: 4 |
Did you manage to find a good solution to this? I also have a need to randomly (uniformly) sample points within cells to perform a Monte Carlo integration. The best way I can think of is to find a minimal box that encloses the cell, and sample over the box with an accept/reject policy to get a list of points in the cell. |
Sample utility bug? For many cloud points in the sampleDict, some are neglected! | brandius | OpenFOAM Post-Processing | 10 | August 22, 2022 09:56 |
Equidistant points on sample surface? | HenningW | OpenFOAM Post-Processing | 0 | August 22, 2016 04:04 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Doxygen documentation | Tanay | OpenFOAM Installation | 9 | September 23, 2011 11:40 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
