How to enable C++11 in wmake?
Old   April 27, 2017, 14:35
Default How to enable C++11 in wmake?
Lukas Lebovitz
lukas.lebo is on a distinguished road
I'm trying to compile a boundary condition that uses some C++11 features.
When using "wmake" I get the error:
/cluster/apps/gcc/4.8.2/include/c++/4.8.2/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
I don't have permission to change the wmake rules in the installation directory. Can I just enable support with the Make/options file?
What do you add to it?
lukas.lebo is offline   Reply With Quote
Old   April 27, 2017, 15:28
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
You can add -std=c++11 to EXE_INC variable in Make/options. Are you trying to compile BC for OpenFOAM 2.x? Since in 4.x -std=c++0x flag (though deprecated) is in rules.
alexeym is offline   Reply With Quote
Old   April 27, 2017, 16:30
Lukas Lebovitz
Thanks I just got it to work with
EXE_INC = \
$(CPP_DEP)\
Then using the commands:
export CPP_DEP='-std=c++11'
wmake
Though now I'm facing like 10 new problems which are no longer related to this title/post. Hurray!
By the way I'm on 2.4.0.
Old   May 3, 2019, 14:28
Hao Li
haolee0928 is on a distinguished road
Hello, I am setting boundary conditions by means of codeStream and the same error appear. Could you tell me: in which Make/options should I add the "-std=c++11"?
Thanks a lot
Originally Posted by alexeym View Post
haolee0928 is offline   Reply With Quote
Old   May 3, 2019, 15:33
Alexey Matveichev
There is not Make/options for codeStream, there is codeOptions section. See example here: https://cpp.openfoam.org/v6/classFoa...odeStream.html.
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 13:28
