Explanation of sinusoidal heat source code on fvOptions
Like Tree2Likes
  • 1 Post By letoppina
  • 1 Post By überschwupper
Old   June 24, 2022, 02:12
Default Explanation of sinusoidal heat source code on fvOptions
Giulia
letoppina is on a distinguished road
I am using OpenFoam version 6 and chtMultiRegionFoam as a solver to simulate a solid body (heat source) exchanging heat with a moving fluid. In order to give a sinusoidal variation of the heat source, I am using fvOptions on the solid region with the following code:
    energySource
        type            scalarCodedSource;
        active          yes;
        timeStart       0;
        duration        1e6;
        name            sourceTime;
    selectionMode   all;
    scalarCodedSourceCoeffs
        selectionMode   all;
                volumeMode      specific;
        fields          (h);
            codeInclude
            codeCorrect
                Pout<< "**codeCorrect**" << endl;
            codeAddSup
                    const Time& time = mesh().time();
                    const scalarField& V = mesh_.V();
                    const vectorField& C = mesh_.C();
                    scalarField& heSource = eqn.source();
            heSource += 2.729e6*sin(2*3.14*0.1*time.value())*V;
                Pout << "***codeAddSup***" << endl;
            codeSetValue
                Pout<< "**codeSetValue**" << endl;
            // Dummy entry. Make dependent on above to trigger recompilation
               code
                    $codeInclude
                    $codeCorrect
                    $codeAddSup
                    $codeSetValue
My code is properly working but I have some questions:
- what does "const scalarField& V = mesh_.V()" mean?
- what does "const vectorField& C = mesh_.C()" mean?
- why heSource has to be multiplied by V?
- what is a dummy entry?
Any further explication about the code is highly appreciated.
Thank you very much for your help!!
saidc. likes this.
letoppina is offline   Reply With Quote
Old   June 24, 2022, 03:22
überschwupper is on a distinguished road
Both are just const references to the cell volume of each cell or cell centers.
Why the heat source is multiplied with V depends on the formulation of the source term. I would guess that the relation derived is normed by the volume and in order get the correct values/dimensions it is multiplied by it.
I dont know the reason or the idea behind a dummy entry. But there are #-symbols has to do with preprocessor directives and inside the directory are the directories defined in your file (for example $AddSup)
letoppina likes this.
überschwupper is offline   Reply With Quote
Old   June 24, 2022, 03:27
Giulia
Originally Posted by überschwupper View Post
Thank you for your reply!
So this means that if I want to give a heat source not dependent on the volume (so an absolute heat source expressed in W and not W/m3) I just have to remove the multiplication of V?
Old   June 24, 2022, 04:09
I cant give you the exact answer to this, because I dont know the exact definiton of your source term. Thats why I mentioned my guess. But it would be the other way as you have written.
Do yoou know the dimensions of the prefactor 2.729e6? Dimensioncontrol could help you here.
chtmultiregionfoam, fvoptions, heat source, regions, sinusoidal
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 15:14
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
