Update FOAM objects after new solver run
Old   May 10, 2017, 16:17
Default Update FOAM objects after new solver run
peterTr is on a distinguished road
Hello everyone.
I'm writing a program, in which I do some calculations, get set of coordinates. I create a mesh and run a solver via system calls; then I load this data in Foam objects, preform calculations with new data, and repeat these steps in a loop.
Initializing objects for the first time seems OK, but I'm not sure, how should I re-load new data into them. I use the following Foam objects:
argList
Time
fvMesh
meshSearch
volFields
I wrapped them in a class and just create a new instance every step, but I get incorrect results when reading volFields, though data files are correct (I checked this with paraview). So how should I re-initialize these objects? I found that some of them have sort of "update" functions, but it's not clear if I should use them or do something else.
Thanks in advance.
peterTr is offline   Reply With Quote
Old   May 11, 2017, 16:26
My problem seems to be solved. I replaced meshSearch::findNearestCell with meshSearch::findCell. It works slower, but gives right results. May be, I just misunderstood the meaning of these functions.
Though I still would like to know if I update objects properly, or there exists better way.
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
[snappyHexMesh] Problem with parallel run of snappyHexMesh Lorenzo92 OpenFOAM Meshing & Mesh Conversion 5 April 15, 2016 04:12
potentialFoam doesnt start?! Sway OpenFOAM Running, Solving & CFD 0 July 2, 2015 07:48
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
