Accessing boundaryField
Hi all,
I am trying to access the boundaryField of velocity and modify that and use it for the next time step calculations. I read in the post https://www.cfd-online.com/Forums/op...read-only.html that we have to use boundaryFieldRef inorder to access it, else it throws an error saying the field is read only. I did as suggested but still the values are not reflected on the output. Are Ref fields only for reference and not for next time step or post-processing? Below is my piece of code in the solver that converts a scalarField'Jw' into a vectorField 'U'. Code:
label upMem = mesh.boundaryMesh().findPatchID("upperMembrane"); |
Solved
I was using noSlip boundary condition for U on the patches where I wanted to change the values. When I changed it to fixed Value (0,0,0), the code that I wrote in the solver was implemented. Hope that helps anyone else with similar issue!
