Construct cellZone based on a cellLabelList
Hi everybody,
I am trying to build a cellZone which has no physical meaning but I want to check it out in paraview. The cellZone I am trying to create has arbitrary (random) cells. E.g. by using the bounding box of the geometry and the Random object class, I make arbitrary positions which I then use to check if there is a cell at that position (mesh.findCell()). After that I have the cellLabels in a labelList which I want to transform to a cellZone now in order to visualize the cells that are selected. Right now, I cannot find anything in Doxygen but I will go to setSets in order to see how it is done there. However, maybe someone is faster and know it already :) |
Hi all,
problem solved and it was easy as always (there might be a better way)
