Home > Forums > OpenFOAM Programming & Development
Wall shear stress and cell area code in SimpleFoam
Old   July 8, 2017, 05:19
Post Wall shear stress and cell area code in SimpleFoam
Francisco Almeida
Fran6 is on a distinguished road
Hi all,
this is my first post. I have been reading a lot about wall shear stress (WSS), I need to calculate it for my thesis, however, I want to obtain the values for wss and area to calculate the average WSS on an artery.
I found different codes looking on previous posts like this,
Improve simpleFoam convergence
write cell volumes
I modified the code (from previous posts) to add the cell area and their locations in the mesh (x y z) but when I try to add the wall shear stress I am unable to. Here is the code I am using, it doesn't contain the WSS yet, I compiled a new simpleFoam solver to run this .H file
Info << "Writing Area of the cells on the patch!" << endl;
word wallPatchName = "walls";
Info << "Searching for patch " << wallPatchName << endl;
// Check, if the patch name exists:
label patchID = mesh.boundaryMesh().findPatchID(wallPatchName);
if (patchID < 0)
Info << "No patch found with name "" << wallPatchName << ""!"
<< endl;
// Pointer to the patch we want to have shear stress for:
const polyPatch& cPatch = mesh.boundaryMesh()[patchID];
label nFaces = cPatch.size();
pointField faceAreas(nFaces, vector(0,0,0));
label runFaces = 0;
// collecting the interesting data
for (int i=0; i<nFaces; i++)
faceAreas[runFaces] = mesh.Sf().boundaryField()[patchID][i];
runFaces++;
// for parallel
reduce(nFaces, sumOp<label>());
Info << "Number of global faces: " << nFaces << endl;
// make a cute filename
fileName casePath = cwd();//casePath.name();
fileName caseName = casePath.name();
fileName myFile = caseName+"_wallShearStress.csv";
Info << "Data is written to file " << myFile << endl;
// create a new file
OFstream *myStream = NULL;
if (Pstream::master())
myStream = new OFstream(myFile);
// slaves send data to master, master writes data to file
if (Pstream:arRun())
if (Pstream::myProcNo() != Pstream::masterNo())
OPstream toMaster(Pstream::blocking, Pstream::masterNo());
toMaster << faceAreas;
else // master part
// first write own data
for (int i=0; i<faceAreas.size(); i++)
*myStream << i << ";"
<< mag(faceAreas[i]) << endl;
label run = faceAreas.size();
// then receive slave data and write
pointField bufferFaceAreas;
for (int slave=Pstream::firstSlave(); slave <= Pstream::lastSlave(); slave++)
IPstream fromSlave(Pstream::blocking, slave);
fromSlave >> bufferFaceAreas;
for (int i=0; i<bufferFaceAreas.size(); i++)
*myStream << run << "; "
<< mag(bufferFaceAreas[i]) << endl;
run++;
else // single processor only
*myStream << i << "; "
// coordinates on face centers:
<< mesh.Cf().boundaryField()[patchID][i].component(0) << "; "
<< mesh.Cf().boundaryField()[patchID][i].component(1) << "; "
<< mesh.Cf().boundaryField()[patchID][i].component(2) << "; "
<< mag(mesh.Sf().boundaryField()[patchID][i]) << endl;
when I try to use the following code I can't compile it, something is wrong with the wall shear stress
#include "RASModel.H"
Info << "Writing wall shear stress for matlab!" << endl;
word wallPatchName = "bottom";
if (patchID < 0)
<< endl;
else
// calculating tau
# include "createFields2.H"
mesh.readUpdate();
volSymmTensorField Reff(RASModel->devReff());
volVectorField tau
IOobject
"tau",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedVector
"tau",
Reff.dimensions(),
vector::zero
forAll(tau.boundaryField(), patchi)
tau.boundaryField()[patchi] =
-mesh.Sf().boundaryField()[patchi]
/mesh.magSf().boundaryField()[patchi]
) & Reff.boundaryField()[patchi];
pointField faceCenterCoords(nFaces, vector(0,0,0));
pointField wallShearStress(nFaces, vector(0,0,0));
label runFaces = 0;
faceCenterCoords[runFaces] = mesh.Cf().boundaryField()[patchID][i];
wallShearStress[runFaces] = tau.boundaryField()[patchID][i];
runFaces++;
// for parallel
fileName myFile = "tau.dat";
toMaster << faceCenterCoords;
toMaster << wallShearStress;
else // master part
for (int i=0; i<faceCenterCoords.size(); i++)
<< faceCenterCoords[i].component(0) << "; "
<< faceCenterCoords[i].component(1) << "; "
<< faceCenterCoords[i].component(2) << "; "
<< wallShearStress[i].component(0) << "; "
<< wallShearStress[i].component(1) << "; "
<< wallShearStress[i].component(2) << "; "
<< mag(wallShearStress[i]) << endl;
label run = faceCenterCoords.size();
pointField bufferFaceCenterCoords;
pointField bufferWallShearStress;
fromSlave >> bufferFaceCenterCoords;
fromSlave >> bufferWallShearStress;
for (int i=0; i<bufferFaceCenterCoords.size(); i++)
*myStream << run << ";"
<< bufferFaceCenterCoords[i].component(0) << "; "
<< bufferFaceCenterCoords[i].component(1) << "; "
<< bufferFaceCenterCoords[i].component(2) << "; "
<< bufferWallShearStress[i].component(0) << "; "
<< bufferWallShearStress[i].component(1) << "; "
<< bufferWallShearStress[i].component(2) << "; "
<< mag(bufferWallShearStress[i]) << endl;
run++;
// wall shear stress as a vector:
<< tau.boundaryField()[patchID][i].component(0) << "; "
<< tau.boundaryField()[patchID][i].component(1) << "; "
<< tau.boundaryField()[patchID][i].component(2) << "; "
// magnitude of wall shear stress:
<< mag(tau.boundaryField()[patchID][i]) << endl;
I get this error
In file included from sempleFoam.C:61:0:
write.H:19:34: fatal error: createFields2.H: No such file or directory
compilation terminated.
/opt/openfoam4/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt32Opt/sempleFoam.o' failed
changing that createfields2.H to createfields.H i get the following,
write.H: In function ‘int main(int, char**)’:
write.H:21:41: error: missing template arguments before ‘->’ token
write.H:43:41: error: passing ‘const Foam::fvPatchField<Foam::Vector<double> >’ as ‘this’ argument discards qualifiers [-fpermissive]
In file included from /opt/openfoam4/src/finiteVolume/lnInclude/fvPatchField.H:592:0,
from /opt/openfoam4/src/finiteVolume/lnInclude/volFields.H:40,
from /opt/openfoam4/src/finiteVolume/lnInclude/surfaceInterpolationScheme.C:27,
from /opt/openfoam4/src/finiteVolume/lnInclude/surfaceInterpolationScheme.H:304,
from /opt/openfoam4/src/finiteVolume/lnInclude/surfaceInterpolate.H:41,
from /opt/openfoam4/src/finiteVolume/lnInclude/fvc.H:39,
from /opt/openfoam4/src/finiteVolume/lnInclude/fvCFD.H:8,
from sempleFoam.C:33:
/opt/openfoam4/src/finiteVolume/lnInclude/fvPatchField.C:395:6: note: in call to ‘void Foam::fvPatchField<Type>:perator=(const Foam::UList<T>&) [with Type = Foam::Vector<double>]’
I just want to obtain the following, cell area, wall shear stress, location of these two and a way to check them in paraView. At the moment I can generate a .csv file with the area and location (thanks to the previous posts)
Is there a way to fix this or to use the existing wallShearStress function in this code?, I am carrying out a Laminar flow simulation on an artery, so turbulence is not important in this case, thanks for your help,
Francisco Almeida
Fran6 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Wall Shear Stress Sampling Probes Mahe88 OpenFOAM Post-Processing 0 December 14, 2016 11:09
Wall Shear Stress prediction varies with fix y+ Jeeloong FLUENT 0 November 24, 2016 18:17
Exporting wall shear stress in relative frame of reference gotang FLUENT 0 September 15, 2014 10:35
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 3 June 12, 2013 02:12
Re: About wall shear stress Mike FLUENT 9 November 17, 2003 15:41
