ggulgulia |
July 8, 2017 10:59 |
Error Duplicate entry swirlFlowRateInletVelocity
Hello Foamer's,
I am trying to compile and use a custom patch type for a swril boundary condition. I do the following steps for it:
1. Copy the .C and .H file in a suitable user directory.
2. In the same directory I create a Make/options and Make/files with following contents:
Make/options
EXE_INC = \
-I$(LIB_SRC)/finiteVolume/lnInclude\
EXE_LIBS =
Make/files
swirlFlowRateInletVelocityFvPatchVectorField.C
LIB_LIB = $(FOAM_USER_LIBBIN)/swirlFlowRateInletVelocity
3. In the directory where .C and .H files are kept i type : wmake libso to compile the patch. From the compilation message every thing seems ok.
4. Next I add the code
libs ("swirlFlowRateInletVelocity.so");
in my system/controlDict.
As far as I know, these are the steps needed for compilation of the boundary.
Now when I type blockMesh on the terminal, I get the error :
Running blockMesh on /home/gajendra/Desktop/sfgsg
Duplicate entry swirlFlowRateInletVelocity in runtime selection table fvPatchField
#0 /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+0x3e) [0x7fa931a9f2ee]
#1 /home/gajendra/OpenFOAM/gajendra-4.1/platforms/linux64GccDPInt32Opt/lib/swirlFlowRateInletVelocity.so(+0xe872) [0x7fa92b845872]
#2 /lib64/ld-linux-x86-64.so.2(+0x106ba) [0x7fa932b4f6ba]
#3 /lib64/ld-linux-x86-64.so.2(+0x107cb) [0x7fa932b4f7cb]
#4 /lib64/ld-linux-x86-64.so.2(+0x158e2) [0x7fa932b548e2]
#5 /lib64/ld-linux-x86-64.so.2(+0x10564) [0x7fa932b4f564]
#6 /lib64/ld-linux-x86-64.so.2(+0x14da9) [0x7fa932b53da9]
#7 /lib/x86_64-linux-gnu/libdl.so.2(+0xf09) [0x7fa9311b2f09]
#8 /lib64/ld-linux-x86-64.so.2(+0x10564) [0x7fa932b4f564]
#9 /lib/x86_64-linux-gnu/libdl.so.2(+0x1571) [0x7fa9311b3571]
#10 /lib/x86_64-linux-gnu/libdl.so.2(dlopen+0x31) [0x7fa9311b2fa1]
#11 /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6dlOpenERKNS_8fileNameEb+0x2f) [0x7fa931a9927f]
#12 /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_8fileNameEb+0x2b) [0x7fa93174030b]
#13 /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_10dictionaryERKNS_4wordE+0xbd) [0x7fa93174052d]
#14 /opt/openfoam4/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam4TimeC1ERKNS_4wordERKNS_7argListES3_S3_+0x4b4) [0x7fa931768244
If anybody can suggest where am I going wrong, it will be really helpful.
Thank you
