Translating a Bisection Method writtern in Matlab to Gmsh!
Old   July 26, 2017, 17:35
Talking Translating a Bisection Method writtern in Matlab to Gmsh!
OpenFoam
CFD-Lover is on a distinguished road
I have written a Bisection method code in Matlab, and I really want to write in Gmsh if that possible. I have read that Gmsh doesn't support the so-called while loop, so I implemented it in Matlab using for loop. Is there any why to implemented in Gmsh. The code is below;
clear all;clc;close all
format long
n = 30;
L = 2;
Start = 0.012;
i = 0:1:(n-1-1);
Function = @(r) L-sum(Start.*r.^i); % anaymos function
low = 0;
high = pi/2;
tol = 0.00001;
mid = (low+high)/2;
for ii=1:ceil(log2(1/tol))
if Function(mid)*Function(high) < 0 % Solution is within upper half
    low = mid;
else % Solution is within lower half
    high = mid;
end
fprintf('Solution lies within [%6.4f, %6.4f]; \n',[low high]);
mid = (low+high)/2;
end
display(mid)
Thank you so much for your time,
CFD-Lover is offline   Reply With Quote
SIMPLE method with matlab houkensjtu Main CFD Forum 9 August 15, 2013 07:28
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 04:35
Code for most powerfull FDV Method D.S.Nasan Main CFD Forum 6 September 4, 2008 02:08
matlab code galerkin method? Mink Main CFD Forum 3 May 23, 2007 06:03
Gudunow method in matlab student Main CFD Forum 2 November 6, 2004 08:32
