Home > Forums > OpenFOAM Programming & Development
Why is this an invalid static_cast of scalarField rA?
Old   August 11, 2017, 15:22
Default Why is this an invalid static_cast of scalarField rA?
Klaus
klausb is on a distinguished road
Why is this operation invalid and how can I fix it?
scalar rA_low = static_cast<float>(rA);
rA is a scalarField in PCG.C, and I need a float version of it which I call rA_low.
I get the following error message:
myMPPCG.C: In member function ‘virtual Foam::solverPerformance Foam::myMPPCG::solve(Foam::scalarField&, const scalarField&, Foam::direction) const’:
myMPPCG.C:115:42: error: invalid static_cast from type ‘Foam::scalarField {aka Foam::Field<double>}’ to type ‘float’
How can I create float versions of scalarFields which are of double type?
Klaus
klausb is offline   Reply With Quote
Old   August 11, 2017, 16:02
Alexey Matveichev
alexeym will become famous soon enoughalexeym will become famous soon enough
Send a message via Skype™ to alexeym
scalarField is a field of scalars (or a list of scalars with certain additional operations defined). How you would like to convert a list into single value? If you know, that your field is uniform, then you can use just first element of the list. If your list is non-uniform, propose your way of converting arbitrary list of floats into single float.
alexeym is offline   Reply With Quote
Old   August 11, 2017, 16:51
Default I am looking for a typecast double > float of all values
Klaus
there's a misunderstanding. My question is about typecasting of the scalar field values.
I need another scalarField with typecast rA(double type values) to rA_low (float type values).
I tried the following to but that doesn't work either:
label rAsize = rA.size();
const scalarField rA_low(rAsize);
forAll(rA_low, i)
scalar s = static_cast<float>(rA[i]);
rA_low[i] = s;
Klaus
Old   August 11, 2017, 17:19
Alexey Matveichev
I think it would be better to call it mis-explanation, cause this:
is an attempt to convert a field rA into a single float.
OK. It seems, your build is "DP", i.e. scalar is, let's call it alias of, double.
So
is a list of doubles. With
you do static cast to float and then assign it to double.
Why no use Field<float> if you want field of floats? Or you can use floatScalar if you want to stay in OpenFOAM types.
Also it would be nice to decipher "that doesn't work either". Does not compile? Does not work as expected? Works from time to time?
Old   August 11, 2017, 18:23
Default How to convert and transfer the content of rA?
Klaus
Thank you for the hints.
Yes the build is DP.
And now I created an empty scalarField rA_low which can take values of type <float>:
floatScalar rA_low(rAsize);
The question is, how to typecast and load the data from rA into rA_low?
Old   August 12, 2017, 03:47
Alexey Matveichev
It seems we are still do not understand each other.
What is wrong with, for example:
Field<float> rA_low(rA.size());
forAll(rA, i) { rA_low[i] = static_cast<float>(rA[i]); }
You are constantly trying to convert FIELD (i.e. list of numbers) into SCALAR (single number).
Old   August 12, 2017, 07:08
Default some steps back...
Klaus
There's rA, a List which contains multiple entries in format <double>.
I need the same List with entries in format <float>, this one I call it rA_low.
The question is how to do such a "typecast conversion" with the List rA?
Old   August 12, 2017, 07:28
Alexey Matveichev
So I repeat my question, what is wrong with type conversion in cycle?
Old   August 12, 2017, 16:19
Klaus
An update, this seems to work:
List<float> rA_low(nCells);
for (int cell=0; cell<nCells; cell++)
     rA_low[cell] = static_cast<float>(rA[cell]);
Thread Tools
Trackbacks are On
parallel simulations - error message: "OPT_ITERATIONS: invalid option name" v8areu SU2 5 July 23, 2015 02:57
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
Problems building Paraview 3.12 on Gentoo Linux pajot OpenFOAM Installation 11 April 11, 2013 08:09
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
