Convection Term
Old   June 4, 2013, 10:25
Default Convection Term
anton_lias is on a distinguished road
Hello Foamers,
I have modified the solver MRFInterFoam to solve the population balance equation via the Quadratic method of Moments.
Now I would like to add the convection term (see attached file)
m is a scalarField
c1 and c2 are constants (scalars)
First I tried this Equation, but I understand, that I can't calculate "scalar - tensor".
fvScalarMatrix mEqn
    U & fvc::grad(m)
    - fvc::grad(c1 * fvc::grad(m1)
    +c2
So I tried this Equation (found in a paper) and add c2 later on.
fvScalarMatrix mEqn
	fvm::div(phi, m)
	- fvm::laplacian(c1, m)
Does this Equation computes the Equation given in the attachment?
Thanks for your help.
anton_lias is offline   Reply With Quote
Old   June 5, 2013, 18:49
Thomas Boucheres
thomasArk47 is on a distinguished road
yes it is better. Don't forget to add the temporal derivative and the source term. Look at applications/solvers/basic/scalarTransportFoam.
thomasArk47 is offline   Reply With Quote
Old   June 6, 2013, 10:05
Thank you Thomas.
Do you mean something like that?
solve
        fvm::ddt(m)
        + fvm::div(phi, m)
        +c2
Old   June 6, 2013, 16:52
Thomas Boucheres
Ok for the time derivative.
For the source term, it is not good. Ok, I assume your "c2" is a fixed variable. This way, you have 2 possibility:
1- use
solve
fvm::ddt(m)
+ fvm::div(phi, m)
fvm::Su(c2f,m)
...where c2f can be declared after the m variable as follows:
DimensionedField<scalar,volMesh> c2f
IOobject
"c2f",
m.time().timeName(),
m.mesh(),
IOobject::NO_READ,
IOobject::NO_WRITE
m.mesh(),
dimensionedScalar("c2f",m.dimensions()/dimTime,c2)
2- cleaner approach by using the fvOptions framework. Needs to write:
solve
fvm::ddt(m)
+ fvm::div(phi, m)
fvOptions(m)
In this approach, you need to define in the right way the fvOptions file located in the system file. Look at the tutorials to find the syntax you need.
N.B : if c2 is not a fixed variable, the first approach is probably the simpler for first try (you could use the second one in combinaison of the codedFunctionObject)
Old   June 18, 2013, 08:02
Thank you thomas its working
Old   August 17, 2017, 13:40
Dongyue Li
sharonyue is on a distinguished road
Hello Lias,
I am working on the Quadratic method of Moments. AFAIK, VOF (interFoam) solve the dispersed phase directly, you dont need the QMOM to track the dispersed phase. Or are you coupling other variables?
sharonyue is offline   Reply With Quote
PISO algorithm for particular NS equation (special convection term) Cyp OpenFOAM Programming & Development 8 June 12, 2012 09:36
[Q] Convection term treatment in UDS Ryan, Lee FLUENT 4 October 18, 2004 10:20
Convection Term Discretization Maciej Matyka Main CFD Forum 3 October 7, 2004 04:32
Convection term with moving grids nicolas FLUENT 0 December 10, 2003 07:34
Additional Convection Term Richard Phoenics 4 March 19, 2001 03:10
