Clarkyan |
August 31, 2017 16:55 |
Could not lad shared library: dlopen error undefined symbol
Dear foamers,
I am trying to write a new dynamic motion solver on the basis of "velocityLaplacian". I copied the source codes of "velocityLaplacian" and wrote to a new library "libMyfvMotionSolvers.so".
The code compiles but when I run the simulation (using interDyMFoam), the following error message comes up (dlopen error):
Selecting motion solver: velocityLaplacian
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1179
dlopen error : /home/xiaohui/OpenFOAM/xiaohui-2.3.1/platforms/linux64GccDPOpt/lib/libMyfvMotionSolvers.so: undefined symbol: _ZN4Foam18fvMotionSolverCore5debugE
--> FOAM Warning :
From function dlLibraryTable::open(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
could not load "libMyfvMotionSolvers.so"
--> FOAM Warning :
From function dlLibraryTable::open(const dictionary&, const word&, const TablePtr&)
in file /home/openfoam/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude/dlLibraryTableTemplates.C at line 67
Could not open library "libMyfvMotionSolvers.so"
--> FOAM FATAL ERROR:
solver table is empty
From function motionSolver::New(const polyMesh& mesh)
in file motionSolver/motionSolver/motionSolver.C at line 116.
FOAM exiting
I tried the following methods but none of them works:
1) change the names;
2) add links to dynamicMesh and dynamicFvMesh etc.;
3) re-install swak4Foam;
etc.
Can anybody drop a hint? Thanks in advance.
Regards,
Clark
