Correct way of defning thermophysicalProperties for rhoCentralFoam
I am wondering what is the correct way of defining thermophysicalProperties for rhoCentralFoam. I am using openfoam v-4.1. In the shockTube tutorial case of rhoCentralFoam, thermophysicalProperties dictionary is as shown below. Code:
// In shockTube case Code:
// In forwardStep case How will the solver detect the way these properties are defined? Or do the units not matter at all? Any help would be greatly appreciated. Thanks, Vachan |
My case is diverging or giving error
Have you found any solution to this situation? I tried to build a case using OF-2106 rhoCentralFoam/forwardStep example case. I replaced the values in U, p, T in 0/ directory with values in S.I units. But the problem either diverges or shows error as following:
1] --> FOAM FATAL ERROR: (openfoam-2012 patch=210618) |
