[Sponsors] | |||||
Mattia
Rep Power: 0 ![]() |
Hello everybody,
I am trying to modify the pimpleFoam solver so that a random perturbation is added at every time step once the momentum equation is solved. For this purpose I found the 'randomise' Field Function Object which looks appropriate for modifying a new field that I want to add as perturbation. Does anyone has any experience using this function? I am quite new both to OpenFOAM and C++ language and I cannot understand exactly how to include it in the solver code (if possible). What I did so far is to create a new field in createFields.H on which I would like this function to act on inside the main code. Also any other documentation of function which works in a similar way or any guide which explains this topic would be very helpful! |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [foam-extend.org] Error compiling OpenFOAM-1.6-ext | Canesin | OpenFOAM Installation | 137 | January 20, 2016 15:56 |
| [mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
| [OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
| is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
| [blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
