Can't add 3rd header filed through Make/options
Recently (after upgrading to openfoam5 and gcc 5.4 and now gcc 6.3) I started running into wmake compile issues e.g. with turbulence models. The problem is, that when I add additional header file locations to Make/options, their content is ignored EXE_INC = \ -I$(LIB_SRC)/OpenFOAM/lnInclude \ -I$/usr/local/header_source_A/include \ >> this has NO effect, header files included in my source code are not found -I$/opt/header_source_B/include >> this has NO effect, header files included in my source code are not found Header files located in /usr/local/header_source_A/include, including header files from /opt/header_source_B/include don't find them. The latter problem includes to some extend the openfoam5/src too but here, I have the impression, that a (substantial) number of symbolic links to lnInclude directories are missing. I reinstalled openfoam5 which had no effect on the problem. The only thing that works is using absolute paths which is impractical. How can I add 3rd party header file locations (directories containing header files) for usage with openfoam5 wmake? Klaus |
I don't think you should add $ before /usr/... and /opt/...
just write -I/usr/local/header_source_A/include \ -I/opt/header_source_B/include |
