using setFields to assign different material properties
Old   December 2, 2017, 01:34
Default using setFields to assign different material properties
Saleh Abuhanieh
Saleh Abuhanieh is on a distinguished road
Hi Foamers,
I am trying to modify the electrostatic solver slightly to be able to read a constant (electric permittivity) with different values from different regions/patches inside the simulation domain.
the solutions which I found were mainly talking about using setField utility.
- Is this the recommended solution?
- If yes, how we can make the solver read it correctly (I am trying now by adding I/O to the createFields.H, it reads but I am not sure if this is the correct way and I have problem with "undefined" variables ) or by making new createFields where I can read from setFieldsDict?
Thank you in advance
Saleh Abuhanieh is offline   Reply With Quote
Old   December 3, 2017, 16:41
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
I would call it easiest and straightforward solution, rather than "recommended".
Post your code, post your error, otherwise it is not clear what modifications you have made.
alexeym is offline   Reply With Quote
Old   December 3, 2017, 22:18
Saleh Abuhanieh
Hi alexeym,
after creating my geometry in Salome, and divide the mesh region using "splitMeshRegions -cellZonesonly -over write", my case folder contains the following:
├── 0
│ ├── cellToRegion
│ ├── epsion
│ ├── phi
│ └── rho
├── constant
│ ├── cellToRegion
│ ├── physicalProperties
│ └── polyMesh
│ ├── boundary
│ ├── cellZones
│ ├── faces
│ ├── neighbour
│ ├── owner
│ └── points
└── system
├── controlDict
├── fvSchemes
├── fvSolution
└── setFieldsDict
the setFieldDict file:
| \\ / O peration | Version: 5 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object setFieldsDict;
defaultFieldValues
volScalarFieldValue epsilon 8.85e-12
regions
zoneToCell
name "SubSimulationDomain_InternalVacuum";
fieldValues
volScalarFieldValue epsilon 20e-12
zoneToCell
name "SubSimulationDomain_MetalShields";
fieldValues
volScalarFieldValue epsilon 30e-12
zoneToCell
name "SubSimulationDomain_ExternalVacuum";
fieldValues
volScalarFieldValue epsilon 40e-12
zoneToCell
name "SubSimulationDomain_Insulator";
fieldValues
volScalarFieldValue epsilon 50e-12
when I run the setFields, I receive the following and nothing happens:
| \\ / O peration | Version: dev-debug |
Build : dev-debug-17954fc1734a
Exec : setFields
Date : Dec 04 2017
Time : 05:57:22
Host : "uuuuuu"
PID : 6832
I/O : uncollated
Case : /home/salehabuhanieh/OpenFOAM/salehabuhanieh-dev-debug/run/Case2Run_multiRegion
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading setFieldsDict
Setting field default values
--> FOAM Warning :
From function bool setCellFieldType(const Foam::word&, const Foam::fvMesh&, const labelList&, Foam::Istream&) [with Type = double; Foam::labelList = Foam::List<int>]
in file setFields.C at line 117
Field epsilon not found
Setting field region values
Adding all cells of cellZone SubSimulationDomain_InternalVacuum ...
Found matching zone SubSimulationDomain_InternalVacuum with 42817 cells.
--> FOAM Warning :
Adding all cells of cellZone SubSimulationDomain_MetalShields ...
Found matching zone SubSimulationDomain_MetalShields with 8391 cells.
--> FOAM Warning :
Adding all cells of cellZone SubSimulationDomain_ExternalVacuum ...
Found matching zone SubSimulationDomain_ExternalVacuum with 70862 cells.
--> FOAM Warning :
Adding all cells of cellZone SubSimulationDomain_Insulator ...
Found matching zone SubSimulationDomain_Insulator with 8618 cells.
--> FOAM Warning :
End
in the original case, it was epsilon0 and defined in the physicalProperties file:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object physicalProperties;
epsilon0 epsilon0 [-1 -3 4 0 0 2 0] 8.85419e-12;
I changed the solver to accept epsilon not epsilon0 nothing more.
The author of this thesis used similar way, (http://webfiles.portal.chalmers.se/e...heHuangMSc.pdf)
If i didn't read the above reference I would have went with the multi region concept like the chtMyltiRegionsSimpleFoam.
I hope my explanation is enough
Old   December 4, 2017, 02:37
Alexey Matveichev
You miss l in epsilon in 0 folder, i.e. in 0 folder you have *epsion* instead of *epsilon*. This causes all those
--> FOAM Warning :
Old   December 4, 2017, 22:33
Saleh Abuhanieh
Thank you alexeym.
it was a silly mistake.
now I can execute setFields successfully with the following output:
Create time
Setting internal values of volScalarField epsilon
End
If I run the solver (myelectrostaticFoam), the solver crashes almost at the same time/way as before changing the standard solver electrostaticFoam:
Exec : myelectrostaticFoam
Date : Dec 05 2017
Time : 06:25:27
Host : "SloOo7"
PID : 14265
I/O : uncollated
nProcs : 1
Create time
Reading physicalProperties
Reading field epsilon
Reading field phi
Reading field rho
Calculating field rhoFlux
Starting iteration loop
Iteration = 5e-05
DICPCG: Solving for phi, Initial residual = 1, Final residual = 0.192831, No Iterations 1
smoothSolver: Solving for rho, Initial residual = 1, Final residual = 1.25419e-11, No Iterations 1
ExecutionTime = 2.41 s ClockTime = 3 s
Iteration = 0.0001
DICPCG: Solving for phi, Initial residual = 1, Final residual = 0.121097, No Iterations 2
smoothSolver: Solving for rho, Initial residual = 4.21734e-12, Final residual = 4.21734e-12, No Iterations 0
ExecutionTime = 2.8 s ClockTime = 3 s
Iteration = 0.00015
smoothSolver: Solving for rho, Initial residual = 4.21733e-12, Final residual = 4.21733e-12, No Iterations 0
ExecutionTime = 3.2 s ClockTime = 3 s
Iteration = 0.0002
ExecutionTime = 3.6 s ClockTime = 4 s
Iteration = 0.00025
ExecutionTime = 3.99 s ClockTime = 4 s
Iteration = 0.0003
ExecutionTime = 4.39 s ClockTime = 5 s
Iteration = 0.00035
ExecutionTime = 4.79 s ClockTime = 5 s
Iteration = 0.0004
ExecutionTime = 5.18 s ClockTime = 5 s
Iteration = 0.00045
ExecutionTime = 5.58 s ClockTime = 6 s
Iteration = 0.0005
ExecutionTime = 5.97 s ClockTime = 6 s
Iteration = 0.00055
#0 Foam::error:rintStack(Foam::Ostream&) at /opt/OpenFOAM-dev-debug/src/OSspecific/POSIX/printStack.C:218
#1 Foam::sigFpe::sigHandler(int) at /opt/OpenFOAM-dev-debug/src/OSspecific/POSIX/signals/sigFpe.C:106
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at /opt/OpenFOAM-dev-debug/src/OpenFOAM/fields/Fields/scalarField/scalarField.C:98 (discriminator 2)
#4 double Foam::gSumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&, int) at /opt/OpenFOAM-dev-debug/src/OpenFOAM/lnInclude/FieldFunctions.C:560
#5 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at /opt/OpenFOAM-dev-debug/src/OpenFOAM/matrices/lduMatrix/solvers/PCG/PCG.C:138 (discriminator 1)
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at /opt/OpenFOAM-dev-debug/src/finiteVolume/fvMatrices/fvScalarMatrix/fvScalarMatrix.C:169 (discriminator 1)
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/OpenFOAM-dev-debug/platforms/linux64GccDPInt32Debug/bin/myelectrostaticFoam"
#8 Foam::fvMatrix<double>::solve() in "/opt/OpenFOAM-dev-debug/platforms/linux64GccDPInt32Debug/bin/myelectrostaticFoam"
#9 Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) in "/opt/OpenFOAM-dev-debug/platforms/linux64GccDPInt32Debug/bin/myelectrostaticFoam"
#10 ? in "/opt/OpenFOAM-dev-debug/platforms/linux64GccDPInt32Debug/bin/myelectrostaticFoam"
#11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12 ? in "/opt/OpenFOAM-dev-debug/platforms/linux64GccDPInt32Debug/bin/myelectrostaticFoam"
Floating point exception (core dumped)
you can see bellow myelectrostatic.C
#include "fvCFD.H"
int main(int argc, char *argv[])
#include "setRootCase.H"
#include "createTime.H"
#include "createMesh.H"
#include "createFields.H"
Info<< "\nStarting iteration loop\n" << endl;
while (runTime.loop())
Info<< "Iteration = " << runTime.timeName() << nl << endl;
solve
fvm::laplacian(phi) + rho/epsilon
rhoFlux = -k*mesh.magSf()*fvc::snGrad(phi);
solve
fvm::ddt(rho) + fvm::div(rhoFlux, rho)
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return 0;
any ideas?
Old   April 19, 2022, 08:31
Zeinab Abosedaira
ZeinabM is on a distinguished road
Since I am trying to use setfields for the same usage as you have here. I'd like to ask about how did you implement the use of setFields exactly. Now you have epsilon, and you're defining it in the physical properties files, but you're also defining it as a Field that has a file in the 0 folder. I don't get exactly how did you manage to implement it. Thank you!
ZeinabM is offline   Reply With Quote
Old   April 19, 2022, 09:37
Saleh Abuhanieh
Hi Zeinab,
It was an old post indeed!
I am not sure what you are trying to do. However, the idea behind the setFields utility is to set a non-uniform values for any fields before starting the simulation.
In the epsilon example, I wanted to set the field values for epsilon (which was used by the solver) differently according to the used material.
The user guide explains the usage of this utility well. Please have a look.
Regards,
Saleh
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 17:00
error message cuteapathy CFX 14 March 20, 2012 06:45
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
