New turbulence model in OF 3 and no proper make file?
Old   March 10, 2016, 03:01
Default New turbulence model in OF 3 and no proper make file?
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
I was trying to add a new turbulence model of my own into OpenFOAM but I found out that the make files corresponding to turbulence models doesn't even contain .C files of the turbulence models.
I am making an alternative turbulence model from kEpsilon. so I have copied kEpsilon from
$SRC/TurbulenceModels/turbulenceModels/RAS/kEpsilon
And the corresponding make files which are located in here:
$SRC/TurbulenceModels/turbulenceModels/Make
But actually there is no kEpsilon.C (or any other .C file of all other turbulence models) included in it. There is no such a thing with OpenFOAM 2.x.
What am I doing wrong?
Thanks all.
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   March 10, 2016, 03:23
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Assuming you need incompressible version of k-epsilon, there is
$FOAM_SRC/TurbulenceModels/incompressible/Make
inside files file there is turbulentTransportModels/turbulentTransportModels.C, and if you look inside $FOAM_SRC/TurbulenceModels/incompressible/turbulentTransportModels/turbulentTransportModels.C, you find:
#define makeRASModel(Type)                                                     \
    makeTemplatedTurbulenceModel                                               \
    (transportModelIncompressibleTurbulenceModel, RAS, Type)
// RAS models
#include "kEpsilon.H"
makeRASModel(kEpsilon);
Not quite sure it fits into the definition of "proper make file".
alexeym is offline   Reply With Quote
Old   March 10, 2016, 03:37
Mojtaba.a's Avatar
Originally Posted by alexeym View Post
// RAS models
Thanks Alexey, I got it.
But I truly wonder why the previous straightforward structure is changed into this.
Old   March 10, 2016, 03:52
Mojtaba.a's Avatar
Another question,
I copied and renamed the kEpsilon model in:
And then I added the following lines:
#include "kEpsilonTest.H"
makeRASModel(kEpsilonTest);
Into:
$SRC/TurbulenceModels/incompressible/turbulentTransportModels/turbulentTransportModels.C
But when I use wmake libso, I get:
could not open file kEpsilonTest.H for source file turbulentTransportModels/turbulentTransportModels.C due to No such file or directory
What are the steps I am missing here?
Thanks.
Old   March 10, 2016, 04:06
Mojtaba.a's Avatar
I manually added links for .C and .H files into:
$SRC/TurbulenceModels/turbulenceModels/lnInclude
And it solved the problem.
Old   March 19, 2016, 22:37
Neilson Whit
wolfindark is on a distinguished road
I try to implement a new LaunderSharmeKE model for compressible spray application in Openfoam-plus
I think this form of implementation a little better for clarity compared to copying all Turbulence directory..... But I have a problem.
You can see the files from the attached zip folder.
My implementation seems working fine but when I run the case (using sprayFoam acheenBomb tutorial) I got the following "Dublicate entry" warning. But the case continue to run.
do you have an idea?
|  \\    /   O peration     | Version:  plus                                  |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : plus-992902758787
Exec   : sprayFoam
Date   : Mar 20 2016
Time   : 12:26:35
Host   : "dynabook"
PID    : 5219
Case   : /home/neo/OpenFOAM/neo-plus/run/aachenBomb
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Duplicate entry laminar in runtime selection table TurbulenceModel
#0	/home/neo/OpenFOAM/OpenFOAM-plus/platforms/linux64GccDPInt32Debug/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+0x27) [0x7ff7f42c2fc9]
#1	/home/neo/OpenFOAM/OpenFOAM-plus/platforms/linux64GccDPInt32Debug/lib/libcompressibleTurbulenceModels.so(_ZN4Foam15TurbulenceModelINS_17geometricOneFieldENS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEENS_27compressibleTurbulenceModelENS_11fluidThermoEE31adddictionaryConstructorToTableINS_7laminarINS_18ThermalDiffusivityINS_27CompressibleTurbulenceModelIS7_EEEEEEEC1ERKNS_4wordE+0xa9) [0x7ff7fcd5d267]
#2	/home/neo/OpenFOAM/neo-plus/platforms/linux64GccDPInt32Debug/lib/MYlibRASModels.so(+0xac78e) [0x7ff7ed7a578e]
#3	/home/neo/OpenFOAM/neo-plus/platforms/linux64GccDPInt32Debug/lib/MYlibRASModels.so(+0xaca1e) [0x7ff7ed7a5a1e]
#4	/lib64/ld-linux-x86-64.so.2(+0x1013a) [0x7ff7fd67d13a]
#5	/lib64/ld-linux-x86-64.so.2(+0x10223) [0x7ff7fd67d223]
#6	/lib64/ld-linux-x86-64.so.2(+0x14c70) [0x7ff7fd681c70]
#7	/lib64/ld-linux-x86-64.so.2(+0xfff4) [0x7ff7fd67cff4]
#8	/lib64/ld-linux-x86-64.so.2(+0x143bb) [0x7ff7fd6813bb]
#9	/lib/x86_64-linux-gnu/libdl.so.2(+0x102b) [0x7ff7f38ba02b]
#10	/lib64/ld-linux-x86-64.so.2(+0xfff4) [0x7ff7fd67cff4]
#11	/lib/x86_64-linux-gnu/libdl.so.2(+0x162d) [0x7ff7f38ba62d]
#12	/lib/x86_64-linux-gnu/libdl.so.2(dlopen+0x31) [0x7ff7f38ba0c1]
#13	/home/neo/OpenFOAM/OpenFOAM-plus/platforms/linux64GccDPInt32Debug/lib/libOpenFOAM.so(_ZN4Foam6dlOpenERKNS_8fileNameEb+0x7e) [0x7ff7f42c0b38]
#14	/home/neo/OpenFOAM/OpenFOAM-plus/platforms/linux64GccDPInt32Debug/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_8fileNameEb+0x42) [0x7ff7f400404e]
#15	/home/neo/OpenFOAM/OpenFOAM-plus/platforms/linux64GccDPInt32Debug/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_10dictionaryERKNS_4wordE+0xa6) [0x7ff7f400446e]
#16	/home/neo/OpenFOAM/OpenFOAM-plus/platforms/linux64GccDPInt32Debug/lib/libOpenFOAM.so(_ZN4Foam4TimeC1ERKNS_4wordERKNS_7argListES3_S3_+0x551) [0x7ff7f401634f]
#17	sprayFoam() [0x48ccfa]
#18	/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7ff7f2cf5ec5]
#19	sprayFoam() [0x48cb29]
Duplicate entry RAS in runtime selection table TurbulenceModel
#1	/home/neo/OpenFOAM/OpenFOAM-plus/platforms/linux64GccDPInt32Debug/lib/libcompressibleTurbulenceModels.so(_ZN4Foam15TurbulenceModelINS_17geometricOneFieldENS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEENS_27compressibleTurbulenceModelENS_11fluidThermoEE31adddictionaryConstructorToTableINS_8RASModelINS_15EddyDiffusivityINS_18ThermalDiffusivityINS_27CompressibleTurbulenceModelIS7_EEEEEEEEEC2ERKNS_4wordE+0xa9) [0x7ff7fcd5d461]
#2	/home/neo/OpenFOAM/neo-plus/platforms/linux64GccDPInt32Debug/lib/MYlibRASModels.so(+0xac857) [0x7ff7ed7a5857]
Duplicate entry LES in runtime selection table TurbulenceModel
#1	/home/neo/OpenFOAM/OpenFOAM-plus/platforms/linux64GccDPInt32Debug/lib/libcompressibleTurbulenceModels.so(_ZN4Foam15TurbulenceModelINS_17geometricOneFieldENS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEENS_27compressibleTurbulenceModelENS_11fluidThermoEE31adddictionaryConstructorToTableINS_8LESModelINS_15EddyDiffusivityINS_18ThermalDiffusivityINS_27CompressibleTurbulenceModelIS7_EEEEEEEEEC1ERKNS_4wordE+0xa9) [0x7ff7fcd5d65b]
#2	/home/neo/OpenFOAM/neo-plus/platforms/linux64GccDPInt32Debug/lib/MYlibRASModels.so(+0xac920) [0x7ff7ed7a5920]
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading g
Creating combustion model
Selecting combustion model PaSR<psiChemistryCombustion>
Selecting chemistry type
    chemistrySolver ode;
    chemistryThermo psi;
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         reactingMixture;
    transport       sutherland;
    thermo          janaf;
    energy          sensibleEnthalpy;
    equationOfState perfectGas;
    specie          specie;
Selecting chemistryReader chemkinReader
Reading CHEMKIN thermo data in new file format
chemistryModel: Number of species = 5 and reactions = 1
Selecting ODE solver seulex
    using integrated reaction rate
Creating component thermo properties:
    multi-component carrier - 5 species
    liquids - 1 components
    solids - 0 components
Reading field U
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model myLaunderSharmaKE
myLaunderSharmaKECoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
Creating field dpdt
Creating field kinetic energy K
No MRF models present
No finite volume options present
Constructing reacting cloud
Constructing particle forces
    Selecting particle force sphereDrag
Constructing cloud functions
    none
Constructing particle injection models
Creating injector: model1
Selecting injection model coneNozzleInjection
    Constructing 3-D injection
Selecting distribution model myRosinRammler
Selecting dispersion model none
Selecting patch interaction model standardWallInteraction
Selecting stochastic collision model none
Selecting surface film model none
Selecting U integration scheme Euler
Selecting heat transfer model RanzMarshall
Selecting T integration scheme analytical
Selecting composition model singlePhaseMixture
Selecting phase change model mySteamCondDropletBoilXx2
Participating liquid species:
    C7H16
Selecting AtomizationModel none
Selecting BreakupModel ReitzDiwakar
Average parcel mass: 2.4e-10
Selecting radiationModel none
Courant Number mean: 0 max: 0
Starting time loop
deltaT = 2.94118e-06
Time = 2.94118e-06
wolfindark is offline   Reply With Quote
Old   March 30, 2017, 02:01
Han Li
lifeinhand is on a distinguished road
Hi wolfindark,
I am having a similar issue "Duplicate entry laminar in runtime selection table TurbulenceModel"..... Did you solve yours?
Regards,
Han
lifeinhand is offline   Reply With Quote
Old   August 10, 2017, 01:00
Neilson Whit
Yes I solved.
Check the attached file
Old   October 13, 2018, 08:55
Xinguang Wang
JasonWang3 is on a distinguished road
Originally Posted by wolfindark View Post
Yes I solved.
Hi there,
I am going to make a modification to the LRR model, and make it, but it does not work. I did make the LS model as you did, it work. I noticed that this two models include different shear stress '.H' files.
Do you have any idea if I want to make LRR model in the original OpenFoam.
regards,
Xinguang
JasonWang3 is offline   Reply With Quote
Old   March 18, 2019, 21:19
Jianrui Zeng
calf.Z is on a distinguished road
Yes I solved.
I have also encountered the duplicated entry problem, How do you solved it? I have checked the file you uploaded but I have not found the solution.
calf.Z is offline   Reply With Quote
