Solving stokes flow
Good afternoon
I'm a new programmer into OpenFOAM, and as a part of a larger development project, I want to start coding the Stokes flow (meaning steady state, without convection term, no body forces and laminar flow). To do so, I started with icoFoam.C and then I implemented the SIMPLE algorithm from the description found on the OpenFOAM wiki https://openfoamwiki.net/index.php/O...hm_in_OpenFOAM I'm not using simpleFoam because I don't need the turbulence either. While compiling I've got the following two errors, which I think are related to the relaxation needed in the SIMPLE algorithm because icoFoam don't need that, but I have no idea how to fix that. error: ‘class Foam::tmp<Foam::fvMatrix<Foam::Vector<double> > >’ has no member named ‘relax’ UEqn.relax(); error: passing ‘const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary’ as ‘this’ argument discards qualifiers [-fpermissive] p.boundaryField().updateCoeffs(); The beginning of my code is: Code:
#include "fvCFD.H" |
