protected scalarList
Old   April 16, 2018, 15:33
Default protected scalarList
Joaquín Neira
cojua8 is on a distinguished road
Hello, I'm trying to add a new member to KinematicParcel class of type List<scalar> to store all (or a defined number) the previous dt.
for this, I added, in file KinematicParcel.H:
protected:
            //- dt storage [s]
            List<scalar> dtList_;
public:
            //- Return const access to the dtList
            inline List<scalar> dtList() const;
            //- Return access to the dtList
            inline List<scalar>& dtList();
In file KinematicParcelI.H:
template<class ParcelType>
inline Foam::List<Foam::scalar> Foam::KinematicParcel<ParcelType>::dtList() const
    return dtList_;
inline Foam::List<Foam::scalar>& Foam::KinematicParcel<ParcelType>::dtList()
    return dtList_;
the in file file KinematicParcel.C (move function), I need to do this:
        if (p.onBoundaryFace() && td.keepParticle)
            if (isA<processorPolyPatch>(pbMesh[p.patch()]))
                td.switchProcessor = true;
                std::cout << "cambio de procesador" << std::endl;
        p.age() += dt;
        p.dtList().append(dt);
        td.cloud().functions().postMove(p, celli, dt, start, td.keepParticle);
    return td.keepParticle;
This works fine when I don't run my problem in multiple processors, but when running it in parallel, after going to a new processor it crashes.
How should I include dtList in the constructors so that it works as I expect and doesn't reset and crash when running in parallel?
Also, how can I set a fixed sized based on variable NB (shown on files attached)?
thank you!
cojua8 is offline   Reply With Quote
list, parallel
Failure to start from latest time when BC stores scalarlist Phicau OpenFOAM Bugs 4 April 13, 2023 04:19
[snappyHexMesh] snappyHexMesh <-> dynamicMeshDict problem with protected cells Billy_16 OpenFOAM Meshing & Mesh Conversion 2 November 21, 2020 03:34
defining a protected variable blows the solution anishtain4 OpenFOAM Programming & Development 1 June 28, 2016 14:39
Combining 2 scalarList into scalarListList? CKH OpenFOAM Programming & Development 1 May 30, 2013 09:39
