June 11, 2018, 14:54 |
Where is the Boltzmann constant value set?
Rep Power: 11 |
I am wondering where the Boltzmann constant value is set in OpenFOAM. The variable k is defined under src/OpenFOAM/global/constants/fundamental/fundamentalConstants.C. I expected to find the value set here too, like for the Avogadro constant. (Actually, NA is the only value set her.) Code:
defineDimensionedConstantWithDefault ( physicoChemical::group, physicoChemical::NA, Foam::dimensionedScalar ( "NA", dimensionSet(0, 0, 0, 0, -1), 6.0221417930e+23 ), constantphysicoChemicalNA, "NA" ); defineDimensionedConstant ( physicoChemical::group, physicoChemical::k, constantphysicoChemicalk, "k" ); If anyone can point me in the right direction, I would be very grateful. Regards, hester |
June 12, 2018, 23:30 |
Martin
Rep Power: 14 |
The Boltzman's constant is is taken as variable by fundamentalConstants.H. Actuallyit is defined at line 41 of file LISASMDCalcMethod2.H. Check https://cpp.openfoam.org/v5/fundamen...stants_8H.html.
June 13, 2018, 05:14 |
Rep Power: 11 |
Hello msaravia,
thank you for your reply. If you look at your mentioned source code, you will see that k in this file is not the Boltzmann constant but it is an integer used for iteration. This is the file the doxygen documentation will lead you to if your looking for physicoChemical::k (as mentioned in my initial post). Regards, hester |
June 17, 2018, 04:55 |
Vince
Rep Power: 9 |
Hi Hester,
The Boltzmann constant value is given in $WM_PROJECT_DIR/etc/controlDict Code:
DimensionedConstants { unitSet SI; // USCS SICoeffs { physicoChemical { mu mu [1 0 0 0 0 0 0] 1.66054e-27; k k [1 2 -2 -1 0 0 0] 1.38065e-23; } } } Vince |
June 18, 2018, 04:47 |
Rep Power: 11 |
Hi Vince,
this is exactly what I was looking for. Thank you! hester |
boltzmann constant |
[ICEM] ICEM Scripting Issues | tylerplowright | ANSYS Meshing & Geometry | 33 | September 27, 2021 16:35 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
How to set a initial temperature and constant heat flux at same BC's?? | Jane | FLUENT | 4 | October 25, 2015 12:01 |
[ICEM] Question about the use of ICEM tcl scripting | lnk | ANSYS Meshing & Geometry | 9 | January 16, 2013 09:24 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
