August 27, 2018, 11:12 |
define CSVfile dict in the BC code
Ignacio Sarmiento
Rep Power: 7 |
Newbie question:
There is a very useful option for reading non uniform values from CSV files with dataentry/function1, but I would like to define this way 5 variables for my BC, so someone could just define every variable in the U dict as: <entryName> csvFile; <entryName>Coeffs { nHeaderLine 4; refColumn 0; // reference column index componentColumns (1); // component column indices separator ","; // optional (defaults to ",") mergeSeparators no; // merge multiple separators fileName "fileXYZ"; // name of csv data file outOfBounds clamp; // optional out-of-bounds handling interpolationScheme linear; // optional interpolation scheme } but it's kind of redundant define all this for the 5 variables changing only componentColumns, it would be more confortable calling it only once, but that is not possible for arbitrary number of variables, actually I only can call scalars, vectors and tensors, so I was thinking in call it directly from the BC code, is that possible? insted writing h_(function1<scalar>::New("h", dict)) put directly in the code h_(function1<scalar>::New("h", { h csvFile; hCoeffs { nHeaderLine 4; refColumn 0; componentColumns dict.lookup("valuesColumns")[0]; separator ","; mergeSeparators no; fileName dict.lookup("dataFileName"),; outOfBounds clamp; interpolationScheme linear; } } ) I know that drafting doesn't actually works, but how can I define this dict in the code so this could work? or is it possible to redefine 1 member of the dict when I call it? Any other suggestions for not calling 5 times the same file changing only the componentColumns? |
boundary condition, csv, csvfile |
UDF error for Heat Generation | mame | Fluent UDF and Scheme Programming | 4 | March 3, 2016 04:22 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 08:10 |
UDF Scalar Code: HT 1 | Greg Perkins | FLUENT | 8 | October 20, 2000 12:40 |
