scalarCodedSource heat sink definition
Hi there,
I am conducting a simulation of a heat exchanger using cyclic boundary conditions containing a heat sink using chtMultiRegionFoam with OpenFOAM v6. I am trying to create a heat sink using scalarCodedSource in FVOptions. I require to measure the heat flux transferred from my metal region to my fluid region at each timestep, and feed this back into my heat sink so that the same amount of heat that is added at each step is removed. Currently I have only been able to get the heat flux across the interface through the post-processing command Code:
chtMultiRegionFoam -postProcess -func wallHeatFlux -region aluminium Any support or suggestions would be of great help Thanks Calum |
