November 28, 2018, 02:06 |
Compiling error
Rep Power: 8 |
Hi all,
I am new in openFoam development work, while compiling source code, i am getting following error. Any help would be appreciated. Thanks in advance ------------------------------------------------------------ $ wmake Making dependency list for source file comfortFoam.C In file included from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/faceZoneMesh.H:33:0, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/polyMesh.H:56, from /opt/OpenFOAM/OpenFOAM-dev/src/finiteVolume/fvMesh/fvMesh.H:50, from /opt/OpenFOAM/OpenFOAM-dev/src/finiteVolume/lnInclude/fvCFD.H:7, from comfortFoam.C:50: /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/faceZone.H:46:32: fatal error: primitiveFacePatch.H: N o such file or directory compilation terminated. x86_64-w64-mingw32-g++ -m64 -std=c++11 -Dcygwin64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -DMSWIN -DLITTLE_ENDIAN -DMSWIN -DLITTLE_ENDIAN -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-p arameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-dev/src /TurbulenceModels/turbulenceModels/lnInclude -I/opt/OpenFOAM/OpenFOAM-dev/src/TurbulenceModels/incompres sible/lnInclude -I/opt/OpenFOAM/OpenFOAM-dev/src/TurbulenceModels/compressible/lnInclude -I/opt/OpenFOAM /OpenFOAM-dev/src/thermophysicalModels/basic/lnInclude -I/opt/OpenFOAM/OpenFOAM-dev/src/transportModels -I/opt/OpenFOAM/OpenFOAM-dev/src/transportModels/incompressible/singlePhaseTransportModel -I/opt/OpenFOA M/OpenFOAM-dev/src/transportModels/compressible/lnInclude -I/opt/OpenFOAM/OpenFOAM-dev/src/finiteVolume/ lnInclude -I/opt/OpenFOAM/OpenFOAM-dev/src/thermophysicalModels/radiation/lnInclude -I/opt/OpenFOAM/Open FOAM-dev/src/meshTools/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude -I/ opt/OpenFOAM/OpenFOAM-dev/src/OSspecific/MSWindows/lnInclude -c comfortFoam.C -o /opt/OpenFOAM/OpenFOA M-dev/platforms/cygwin64mingw-w64DPInt32Opt/applications/solvers/comfortFoam/comfortFoam.o In file included from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/faceZoneMesh.H:33:0, from /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/polyMesh.H:56, from /opt/OpenFOAM/OpenFOAM-dev/src/finiteVolume/fvMesh/fvMesh.H:50, from /opt/OpenFOAM/OpenFOAM-dev/src/finiteVolume/lnInclude/fvCFD.H:7, from comfortFoam.C:50: /opt/OpenFOAM/OpenFOAM-dev/src/OpenFOAM/lnInclude/faceZone.H:46:32: fatal error: primitiveFacePatch.H: N o such file or directory compilation terminated. make: *** [/opt/OpenFOAM/OpenFOAM-dev/wmake/rules/General/transform:26: /opt/OpenFOAM/OpenFOAM-dev/platf orms/cygwin64mingw-w64DPInt32Opt/applications/solvers/comfortFoam/comfortFoam.o] Error 1 ------------------------------------------------------------------------------------ |
November 30, 2018, 07:29 |
Rep Power: 10 |
As the error says, you're missing the file (actually, like to the file) 'primitiveFacePatch.H' at src/OpenFOAM/lnInclude. Please check if it is present at the location. If not, you may try running 'wmake dep' to build the lnInclude directory again from src/OpenFOAM directory. USV |
November 30, 2018, 07:37 |
Rep Power: 12 |
Thanks for reply! Initially, i am using openFoam version 2.3 and encountered aforesaid error. Now i have used version 5, its working fine. Regards M. Ariz |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 06:25 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
