y+ and u+ calculation
Like Tree4Likes
  • 3 Post By tilasoldo
  • 1 Post By jherb
Old   January 24, 2019, 12:43
Default y+ and u+ calculation
Xavier Lamboley
tilasoldo is on a distinguished road
Hello Foamers,
I want to calculate y+ = y u* / nu and u+ = u / u* with functionObjects in Openfoam.
I managed to retrieve y as a wallDist, nu from the turbulence model and U. I also get u* as a volScalarField, defined only on the wall patch (zero elsewhere), with another functionObject.
Now in order to calculate u+ and y+ in the whole field, I need to use for every cell the value of u* on the closest face on the boundary. I don t have any clue on how to do that...
You will find attached the code of my 3 functionObjects for u*, y+ and u+, which use for now the average of u* on the patch.
Any help would be greatly appreciated.
X. Lamboley
turbulence_functionObjects.tar.gz
tilasoldo is offline   Reply With Quote
Old   January 28, 2019, 04:11
Xavier Lamboley
After some investigation I found a solution by looping over the mesh points. You will find attached the updated code.
The method is to loop over the mesh points, then looping over the surface faces. I keep the nearest x on the surface for each mesh point, and assign its wallShearStress.
This works well, if the point are sufficiently aligned along the vertical.
Cheers,
X. Lamboley
aerospaceman, jherb and chiachun96 like this.
Old   April 13, 2019, 15:54
Joachim Herb
jherb is on a distinguished road
Thank you for sharing the code. Could you please also give an example, how to use this in the controlDict. Or how do you else use function objects?
aerospaceman likes this.
jherb is offline   Reply With Quote
Old   July 6, 2019, 04:54
Jianrui Zeng
calf.Z is on a distinguished road
I am also in u+ calculation. Could you give more explanation? Thanks.
calf.Z is offline   Reply With Quote
Dynamic mesh adaption in parallel calculation xh110120 FLUENT 1 March 12, 2016 09:05
Determining the calculation sequence of the regions in multe regions calculation peterhess OpenFOAM Running, Solving & CFD 4 March 9, 2016 04:07
Increase in CPU number during the FIRE calculation amin_u50 AVL FIRE 0 August 6, 2014 09:34
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 09:46
Warning 097- AB Siemens 6 November 15, 2004 05:41
