What is ".*" in pointDisplacement file?
Old   February 12, 2019, 16:58
Default What is ".*" in pointDisplacement file?
Andrew Somorjai
massive_turbulence is on a distinguished road
Hello all,
I just wondered if ".*" means "for all" patches in this snippet from a pointDisplacement file; kind of like in SQL where you use something like "select * from ..."?
boundaryField
        type            uniformFixedValue;
        uniformValue    (0 0 0);
thanks!
massive_turbulence is offline   Reply With Quote
Old   February 12, 2019, 17:04
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
It is a regex (regular expression) - POSIX flavour.
olesen is offline   Reply With Quote
Old   February 12, 2019, 17:06
Andrew Somorjai
What does it mean though, does it simply apply to every patch that is not otherwise defined in the same file?
Old   February 12, 2019, 17:54
clapointe is on a distinguished road
Yes. You could test this by removing it -- should trigger a crash and a message to the effect of "patch not defined in pointDisplacement.boundaryField".
Caelan
clapointe is offline   Reply With Quote
Old   February 12, 2019, 18:19
Andrew Somorjai
Caelan
I see, on wikipedia it says
"s.* matches s followed by zero or more characters, for example: "s" and "saw" and "seed"."
patch, select, types
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
