Customize linearSpring restraint
Old   May 23, 2016, 08:50
Default Customize linearSpring restraint
Federica Biano
federicabi is on a distinguished road
Hi everyone!
I'm stuck on a problem, because I'm new in programming in openFOAM. I need to compile a new restraint similar to linearSpring, so I took a look at the .H and .c files of linearSpring restraint and I need to modify the restraintForce term with a time varying force composed like this: (Fx,0,Fx*tan(alpha)).
Fx is the sum of Fx pressure and Fx viscous and it needs to be extract each time step from the forces.dat file. alpha is the angle between the initial position of the x-axis of the system and the new position, I think it can be extract from the motion.orientation() tensor each time step. The problem is that I don't know how to extract these data to put them into the linearSpring library.
I tried to modify the library like below
void Foam::sixDoFRigidBodyMotionRestraints::linearSprin g::restrain
const sixDoFRigidBodyMotion& motion,
vector& restraintPosition,
vector& restraintForce,
vector& restraintMoment
) const
restraintPosition = motion.transform(refAttachmentPt_);
vector r = restraintPosition - anchor_;
scalar magR = mag(r);
r /= (magR + VSMALL);
vector v = motion.velocity(restraintPosition);
restraintForce = vector(Fx,0,Fx*tan(alpha))
restraintMoment = vector::zero;
if (motion.report())
Info<< " attachmentPt - anchor " << r*magR
<< " spring length " << magR
<< " force " << restraintForce
<< endl;
Now I need to build a new function in this dictionary to extract Fx and alpha.
Anyone knows how can I do that?
Your help would be very appreciated.
Best regards
Federica
federicabi is offline   Reply With Quote
Old   May 30, 2016, 05:21
Federica Biano
I have tried to write the code and then to compile it, but openFOAM gives me errors. In particular I'm worried about this error
In file included from linearSpringFede1.C:26:0:
linearSpringFede1.H: In member function ‘virtual Foam::autoPtr<Foam::sixDoFRigidBodyMotionRestraint > Foam::sixDoFRigidBodyMotionRestraints::linearSprin gFede1::clone() const’:
linearSpringFede1.H:104:44: error: cannot allocate an object of abstract type ‘Foam::sixDoFRigidBodyMotionRestraints::linearSpri ngFede1’
new linearSpringFede1(*this)
linearSpringFede1.H:56:7: note: because the following virtual functions are pure within ‘Foam::sixDoFRigidBodyMotionRestraints::linearSpri ngFede1’:
class linearSpringFede1
I haven't modified this part, except for the name of the restraint.
Do you know how can I fix it?
Best regards
Federica
Old   June 9, 2016, 09:42
Thumbs up Solved
Federica Biano
Solved.
I added 3 more variables to a function argument, into the header file, instead defining them into the function itself.
Old   March 28, 2019, 06:18
Mohamad
mhasif02 is on a distinguished road
Hi Federica,
I'm having the same error when compiling this linearSpring restraint. How did you fix it? what did you add inside the .H file?
Mohamad
mhasif02 is offline   Reply With Quote
forces, linearspring
SixDoFRigidBodyMotion under OF2.3 ( self oscillating cylinder) Scabbard OpenFOAM Running, Solving & CFD 1 July 22, 2014 04:50
how to customize the initial velocity and temperature field? gdtiaozi FLOW-3D 1 December 3, 2013 07:13
How to customize FLOW-3D in Windows? therockyy FLOW-3D 1 December 9, 2010 16:43
Customize Heat Flux Distribution Using UDF Ken Adams FLUENT 0 May 25, 2007 15:25
Can I Customize Fluent Environment venugopal FLUENT 0 June 16, 2004 12:15
