Antti Hellsten model: New Advanced k–ω Turbulence Model for High-Lift Aerodynamics |
April 3, 2019, 10:19 |
Thanks for your attention.
Purpose of this thread- I am looking for help on the above title which I'll call "Hellsten model" (2005. I am a student and new to the OpenFOAM software. Currently, I am working on a project and the first step of this project is a simulation of flow over a flat plate using the Hellsten model). The problem is I can't find any pre-developed Hellsten model anywhere on the internet. So, I want to request that if someone has already developed this model in OpenFOAM then kindly share it with me. If no one has then can you please take a look at this model and suggest me which other model has a similar structure and is available for OF so that I can edit this second model into the Hellsten model. Thank you in advance for the time you are going to put for me. 1. I am using OF1812+ on Ubuntu 1804. 2. Here is the link of the Hellsten model: https://drive.google.com/open?id=1EJ...tplVWS6_TqR6i- |
April 6, 2019, 12:50 |
Michael Alletto
You can find something similar in this masterthesis https://www.google.com/url?sa=t&sour...AFUhDtzdYAHvQP. Source code is in the thesis. The may be a starting point for your thesis.
April 6, 2019, 14:07 |
Michael Alletto
This may also be usefull A new EARSM turbulence model implementation
May 10, 2019, 12:29 |
1. Thank you very much for your time and effort, Sir Allento. I'll take references from the above sources.
2. Because those codes are developed for old versions of OF, I am posting a new thread with a fresh question: Antti Hellsten model: New Advanced k–ω Turbulence Model 3. Can anyone suggest me which standard RAS model supplied with OF1812+ I should use to edit and develop my own model of AnttiHellsten? The list of RAS models available is : 20 ( LRR LamBremhorstKE LaunderSharmaKE LienCubicKE LienLeschziner RNGkEpsilon SSG ShihQuadraticKE SpalartAllmaras bslearsm kEpsilon kEpsilonLopesdaCosta kOmega kOmegaSST kOmegaSSTLM kOmegaSSTSAS kkLOmega qZeta realizableKE v2f ) Last edited by purnp2; May 10, 2019 at 15:30. |
earsm, hellsten, k-omega model, k-w model, turbulence model |
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 02:08 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Turbulence model for Aerodynamics | David Baker | Siemens | 3 | August 6, 2003 04:16 |
Why Turbulence models are not universal. | Senthil | Main CFD Forum | 4 | July 5, 2000 04:34 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 03:27 |
