raunakbardia |
June 2, 2019 15:46 |
OpenFOAM class declaration error with volScalarField
3 Attachment(s)
Hi everyone,
I am currently using OpenFOAM v1706.
I am trying to declare a class with the internal field of a volScalarField object and a volVectorField object. During class instantiation, I simply want them to be initialized with a uniform zero value. Even though I have copied the constructors used in other OpenFOAM libraries, I am not able to make them work.
Here is the code definition for the volScalarField object.
In .H file, the variable is defined as:
volScalarField::Internal alphaSource_;
Class instantiation in the .C file uses the following code:
alphaSource_
IOobject
"alphaSource",
mesh_.time().timeName(),
mesh_
mesh_,
dimensionedScalar("zero", dimVol, 0)
I have attached the error log, but I believe the main error is the following:
In file included from /usr/local/openfoam/v1706/OpenFOAM-v1706/src/finiteVolume/lnInclude/fvMesh.H:58:0,
from phaseChangeAdvection.H:57,
from phaseChangeAdvection.C:29:
/usr/local/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude/DimensionedField.H: In instantiation of ‘class Foam::DimensionedField<double, Foam::volMesh>’:
/usr/local/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude/GeometricField.H:81:7: required from ‘class Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>’
phaseChangeAdvection.H:110:23: required from here
/usr/local/openfoam/v1706/OpenFOAM-v1706/src/OpenFOAM/lnInclude/DimensionedField.H:84:40: error: invalid use of incomplete type ‘class Foam::volMesh’
typedef typename GeoMesh::Mesh Mesh;
Any help would be much appreciated. I have always come across some or the other error in instantiating a volScalarField object in a class but every time I have used a workaround. Don't want to keep ignoring this forever.
