June 13, 2019, 08:29 |
extract surfaces
Hi all,
I'm changing the code in such a way I can extract surface average of some variable at every deltat (no time step). I don't want to use any kind of postProcess function but directly change the main code. I'd like do something like that: but referring in general to a surface at a fixed z, not only to boundaryField(). I want to replace this cycle with a cycle over height. What I can use instead of .boundaryField() ? What field of 'mesh' I have to access to? Where I can find more detail about OpenFOAM classes/structure? Hope to have been clear, Sara |
extract surfaces |
Extracting results on multiple surfaces | sunilpatil | FLUENT | 0 | October 21, 2018 11:15 |
Cannot extract surfaces of the .vtk file in Paraview | cfdcar | SU2 | 4 | August 15, 2018 09:46 |
[snappyHexMesh] SHM not snapping to some surfaces | Swift | OpenFOAM Meshing & Mesh Conversion | 13 | January 4, 2016 01:56 |
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 | s.mishra | ANSYS | 0 | March 31, 2012 04:12 |
Extract surfaces? | HP | FLUENT | 3 | August 15, 2005 10:16 |
