How to impose both normal and tangential gradient boundary conditions for U and p
Like Tree1Likes
  • 1 Post By HPE
Old   June 17, 2019, 07:01
Default How to impose both normal and tangential gradient boundary conditions for U and p
mtgoncalves is on a distinguished road
I am simulating incompressible laminar external flows in 2D (e.g. flow past cylinder, airfoil, etc.). For this I am using a hybrid solver consisting of pimpleFoam coupled to another non-OpenFOAM solver. I use pimpleFoam only to simulate the near-body flow. The meshes I use are small: the numerical boundary is close to the solid body. Hence, the boundary conditions I need to impose for U and p are unsteady and non-uniform.
With the external solver I can compute the velocity, velocity gradient, pressure and pressure gradient at the coordinates of the face centers at the boundary of the mesh used by pimpleFoam. To impose these conditions I have modified the inletOutlet and outletInlet boundary conditions such that I can change at each time step the:
  • refValue for velocity at inlet faces
  • refGradient for pressure at inlet faces
  • refGradient for velocity at outlet faces
  • refValue for pressure at outlet faces
The problem I am facing now is that for the gradients I am now only imposing the normal component. Because I can get everything from the external solver I would also like to impose the tangential component of the gradients.
So my question is: what do I need to modify in inletOutlet and outletInlet such that I can impose the actual gradients and not merely their normal component.
ps: If it makes more sense to start development from a different boundary condition (e.g. mixed or directionMixed) please tell me.
mtgoncalves is offline   Reply With Quote
Old   May 6, 2020, 10:20
thabuis is on a distinguished road
If you solve your problem, I would be interested in knowing the answer
thabuis is offline   Reply With Quote
Old   May 6, 2020, 16:30
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
if there is a code example, we may try to work on that.
rockFish1007 likes this.
HPE is offline   Reply With Quote
boundary conditions, inlet and outlet, neuman conditions, neumann boundary
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
Calculation Tangential & Normal gradients of a Scalar near a surface. AnthonyP OpenFOAM Programming & Development 12 July 22, 2020 09:01
Slip and Symmetry boundary conditions giuse OpenFOAM Programming & Development 3 December 20, 2016 03:21
Surface normal velocity BC with zero gradient tangential, cylinder c_dowd OpenFOAM Running, Solving & CFD 0 May 25, 2013 07:22
Radial and Tangential Velocity boundary conditions N. A. OpenFOAM 4 September 2, 2011 07:21
