Launching multiple CFD simulations in parallel on cluster
Old   August 14, 2019, 20:53
Default Launching multiple CFD simulations in parallel on cluster
John Thornton
jthornton232 is on a distinguished road
I have created a utility for OpenFOAM V4 which allows me to run multiple serial simulations in parallel using MPI. I have this working on my workstation but I want to run it on a cluster at work. However when I submit the job to the cluster I get messages saying "ctrl_connect/connect: Connection refused". I seem to get this problem only when I run OpenFOAM executables (I have run other simple programs in parallel without issue).
The program is below:
#include "fvCFD.H"
int main(int argc, char *argv[])
argList::validArgs.append("folderName");
argList::validArgs.append("runFileName");
argList args(argc, argv);
if (!args.check()) {
FatalError.exit();
word folderName = args[1]; // folder name from user
int rank = Pstream::myProcNo(); // processor rank
word folder = folderName+name(rank+1); // folder name with the rank
if (!isDir(folder)){ // check if folder exists
FatalErrorInFunction << folder << " does not exist." << exit(FatalError);
word fileName = args[2]; // file name from user
if (!isFile(folder+"/"+fileName)){ // check if file exists
FatalErrorInFunction << folder << "/" << fileName << " does not exist." << exit(FatalError);
system(folder+"/"+fileName); // run the given folder
return 0;
And here is the output when run:
| \\ / O peration | Version: 4.x |
| \\/ M anipulation | |
Build : 4.x-d214c8dfd5ba
Exec : multiFolderRun -parallel MISP Allrun
Date : Aug 14 2019
Time : 17:22:39
Host : "r585i1n9"
PID : 34800
Case : /nobackupp12/jmthorn4/PATO_Cases/TC1-driver/ALLMISPS/test
nProcs : 7
Slaves :
6
"r585i1n9.34801"
"r585i1n9.34802"
"r585i1n9.34803"
"r585i1n9.34804"
"r585i1n9.34805"
"r585i1n9.34806"
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
allowSystemOperations : Allowing user-supplied system call operations
Finalising parallel run
Can anyone shed some light on the issue?
jthornton232 is offline   Reply With Quote
cluster computing, mpi, parallel code
Fluent parallel computation using Xeon duo-processor with CFD occupation below 50% zhujj09 FLUENT 1 October 19, 2016 15:02
problem about running parallel on cluster killsecond OpenFOAM Running, Solving & CFD 3 July 23, 2014 21:13
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Parallel cluster solving with OpenFoam? P2P Cluster? hornig OpenFOAM Programming & Development 8 December 5, 2010 16:06
