OpenFOAM Immersed Boundary Method - forceBased motion class creation |
Rep Power: 7 ![]() |
Hello, I am posting this to help anyone out who is encountering the same error I did when following the tutorial for implementing forceBased IBM motion. The useful tutorial is given at: http://www.tfd.chalmers.se/~hani/kur...eirsson/OF.pdf
When I compiled the files using wmake, I got some errors: Code:
forceBased/forceBased.C: In member function ‘Foam::vector Foam::solidBodyMotionFunctions::forceBased::newPosition() const’: forceBased/forceBased.C:57:30: error: expected primary-expression before ‘.’ token scalar dT = time_.deltaT(.value()); ^ forceBased/forceBased.C:70:31: error: ‘g_l’ was not declared in this scope Info << "Gravity: " << g_l << endl; ^~~ forceBased/forceBased.C:70:31: note: suggested alternative: ‘g_’ Info << "Gravity: " << g_l << endl; ^~~ g_ forceBased/forceBased.C:72:32: error: ‘imBForces_’ was not declared in this scope vector pressureForces = imBForces_.calcForcesMoment().first().first(); ^~~~~~~~~~ forceBased/forceBased.C:72:32: note: suggested alternative: ‘forces_H’ vector pressureForces = imBForces_.calcForcesMoment().first().first(); ^~~~~~~~~~ forces_H forceBased/forceBased.C:109:31: error: ‘imBForces_’ was not declared in this scope vector pressureForces = imBForces_.calcForcesMoment(.first(.second())); ^~~~~~~~~~ forceBased/forceBased.C:109:31: note: suggested alternative: ‘forces_H’ vector pressureForces = imBForces_.calcForcesMoment(.first(.second())); ^~~~~~~~~~ forces_H forceBased/forceBased.C:109:59: error: expected primary-expression before ‘.’ token vector pressureForces = imBForces_.calcForcesMoment(.first(.second())); ^ forceBased/forceBased.C:109:66: error: expected primary-expression before ‘.’ token vector pressureForces = imBForces_.calcForcesMoment(.first(.second())); ^ forceBased/forceBased.C:110:58: error: expected primary-expression before ‘.’ token vector viscousForces = imBForces_.calcForcesMoment(.first(.second())); ^ forceBased/forceBased.C:110:65: error: expected primary-expression before ‘.’ token vector viscousForces = imBForces_.calcForcesMoment(.first(.second())); ^ forceBased/forceBased.C:119:49: error: found ‘:’ in nested-name-specifier, expected ‘::’ vector velocity_ = velocity_+totalForce*dT: ^ forceBased/forceBased.C:119:47: error: ‘dT’ is not a class, namespace, or enumeration vector velocity_ = velocity_+totalForce*dT: ^~ forceBased/forceBased.C:123:22: error: ‘newPos’ was not declared in this scope oldPosition_ = newPos; ^~~~~~ forceBased/forceBased.C: In constructor ‘Foam::solidBodyMotionFunctions::forceBased::forceBased(const Foam::dictionary&, const Foam::Time&)’: forceBased/forceBased.C:151:5: error: class ‘Foam::solidBodyMotionFunctions::forceBased’ does not have any field named ‘imBForces_’ imBForces_("test", time_.lookupObject<objectRegistry>(polyMesh::defaultRegion), SBMFCoeffs_, true) ^~~~~~~~~~ forceBased/forceBased.C: In member function ‘virtual Foam::septernion Foam::solidBodyMotionFunctions::forceBased::transformation() const’: forceBased/forceBased.C:174:4: error: ‘quarternion’ was not declared in this scope quarternion::I ^~~~~~~~~~~ forceBased/forceBased.C:174:4: note: suggested alternative: ‘quaternion_H’ quarternion::I ^~~~~~~~~~~ quaternion_H forceBased/forceBased.C: In member function ‘virtual Foam::septernion Foam::solidBodyMotionFunctions::forceBased::velocity() const’: forceBased/forceBased.C:187:9: error: ‘quarternion’ has not been declared quarternion::I/time_.deltaT().value() ^~~~~~~~~~~ forceBased/forceBased.dep:515: recipe for target 'Make/linux64GccDPOpt/forceBased.o' failed I believe the tutorial forgets to mention that you must declare imBForces_ in the forceBased.H file. There are also some syntax changes to be made to the forceBased.C file. Here is the forceBased.H file: Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | foam-extend: Open Source CFD \\ / O peration | Version: 4.0 \\ / A nd | Web: http://www.foam-extend.org \\/ M anipulation | For copyright notice see file Copyright ------------------------------------------------------------------------------- License This file is part of foam-extend. foam-extend is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. foam-extend is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with foam-extend. If not, see <http://www.gnu.org/licenses/>. Class Foam::solidBodyMotionFunctions::forceBased Description Translation motion function with sine law ramping for velocity. SourceFiles forceBased.C \*---------------------------------------------------------------------------*/ #ifndef forceBased_H #define forceBased_H #include "solidBodyMotionFunction.H" #include "immersedBoundaryForces.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // namespace Foam { namespace solidBodyMotionFunctions { /*---------------------------------------------------------------------------*\ Class forceBased Declaration \*---------------------------------------------------------------------------*/ class forceBased : public solidBodyMotionFunction { // Private data // This has been modified according to http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2016/EliasSiggeirsson/OF.pdf vector g_; scalar still_; scalar mass_; mutable vector velocity_; mutable vector oldPosition_; mutable scalar currentTime_; immersedBoundaryForces imBForces_; // Private Member Functions //- Disallow copy construct forceBased(const forceBased&); //- Disallow default bitwise assignment void operator=(const forceBased&); //- Position calculations vector newPosition() const; vector newVelocity() const; public: //- Runtime type information TypeName("forceBased"); // Constructors //- Construct from components forceBased ( const dictionary& SBMFCoeffs, const Time& runTime ); // Destructor virtual ~forceBased(); // Member Functions //- Return the solid-body motion transformation septernion virtual septernion transformation() const; //- Return the solid-body motion velocity virtual septernion velocity() const; //- Update properties from given dictionary virtual bool read(const dictionary& SBMFCoeffs); }; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // } // End namespace solidBodyMotionFunctions } // End namespace Foam // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #endif // ************************************************************************* // And here is the forceBased.C file which worked for me: Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | foam-extend: Open Source CFD \\ / O peration | Version: 4.0 \\ / A nd | Web: http://www.foam-extend.org \\/ M anipulation | For copyright notice see file Copyright ------------------------------------------------------------------------------- License This file is part of foam-extend. foam-extend is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. foam-extend is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with foam-extend. If not, see <http://www.gnu.org/licenses/>. \*---------------------------------------------------------------------------*/ #include "forceBased.H" #include "addToRunTimeSelectionTable.H" #include "mathematicalConstants.H" using namespace Foam::mathematicalConstant; // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * // namespace Foam { namespace solidBodyMotionFunctions { defineTypeNameAndDebug(forceBased, 0); addToRunTimeSelectionTable ( solidBodyMotionFunction, forceBased, dictionary ); }; }; // * * * * * * * * * * * * * Private Member Functions * * * * * * * * * * * // //Theforcebased.Cfile is set to run with a stationary object for the first still_time steps and thenwith a constant velocity of 0.01 for the next still_time steps and then to be set loose. Foam::vector Foam::solidBodyMotionFunctions::forceBased::newPosition() const { scalar t = time_.value(); scalar dT = time_.deltaT().value(); if (t < (still_*dT+currentTime_)) { return oldPosition_; } else if (t < 2*(still_*dT)) { if (t > currentTime_) { currentTime_ = t; vector gravityForce = mass_*g_; Info << "Gravity: " << g_ << endl; Info << "Gravitational Force: " << gravityForce << endl; vector pressureForces = imBForces_.calcForcesMoment().first().first(); vector viscousForces = imBForces_.calcForcesMoment().first().second(); vector totalForce = gravityForce + pressureForces + viscousForces; Info << "Pressure Force: " << pressureForces << endl; Info << "Viscous Force: " << viscousForces << endl; Info << "Total Force: " << totalForce << endl; Info << "Delta t: " << dT << endl; Info << "Old position : " << oldPosition_ << endl; vector velocity(0.01,0,0); vector dx = velocity*dT; Info << "old velocity: " << velocity_ << endl; velocity_ = vector(0,0,0);//dx/dT;//velocity_+totalForce/mass_*dT; Info << "new velocity: " << velocity_ << endl; vector newPos=oldPosition_+dx; Info << "new position: " << newPos << endl; Info << "new old position: " << oldPosition_ << endl; oldPosition_ = newPos; return oldPosition_; } else { return oldPosition_; } } else { if (t > currentTime_) { currentTime_ = t; vector gravityForce = mass_*g_; Info << "Gravity: " << gravityForce << endl; vector pressureForces = imBForces_.calcForcesMoment().first().second(); vector viscousForces = imBForces_.calcForcesMoment().first().second(); vector totalForce = gravityForce + pressureForces + viscousForces; Info << "Force first: " << pressureForces << endl; Info << "Force second: " << viscousForces << endl; Info << "Total forst pos: " << totalForce << endl; Info << "Delta t: " << dT << endl; Info << "old position: " << oldPosition_ << endl; vector velocity_ = velocity_+totalForce*dT; vector newPos=oldPosition_+velocity_*dT+0.5*totalForce/mass_*pow(dT,2); oldPosition_ = newPos; Info << "new position: " << newPos << endl; Info << "old position: " << oldPosition_ << endl; Info << "velocity, pos: " << velocity_ << endl; oldPosition_ = newPos; return oldPosition_; } else { return oldPosition_; } } } // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // Foam::solidBodyMotionFunctions::forceBased::forceBased ( const dictionary& SBMFCoeffs, const Time& runTime ) : solidBodyMotionFunction(SBMFCoeffs, runTime), g_(0,0,0), velocity_(0,0,0), oldPosition_(0,0,0), currentTime_(0.0), imBForces_("test", time_.lookupObject<objectRegistry>(polyMesh::defaultRegion), SBMFCoeffs_, true) { read(SBMFCoeffs); } // * * * * * * * * * * * * * * * * Destructors * * * * * * * * * * * * * * * // Foam::solidBodyMotionFunctions::forceBased::~forceBased() {} // * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * * // Foam::septernion Foam::solidBodyMotionFunctions::forceBased::transformation() const { septernion TR; TR = septernion ( newPosition(), quaternion::I ); return TR; } Foam::septernion Foam::solidBodyMotionFunctions::forceBased::velocity() const { septernion TV ( velocity_, quaternion::I/time_.deltaT().value() ); Info<< "solidBodyMotionFunctions::forceBased::transformation(): " << "Time = " << time_.value() << " velocity: " << TV << endl; return TV; } bool Foam::solidBodyMotionFunctions::forceBased::read ( const dictionary& SBMFCoeffs ) { solidBodyMotionFunction::read(SBMFCoeffs); SBMFCoeffs_.lookup("gravity") >> g_; SBMFCoeffs_.lookup("mass") >> mass_; SBMFCoeffs_.lookup("stationary") >> still_; return true; } // ************************************************************************* // |
Thomas Shi
Rep Power: 9 ![]() |
Hello! Firstly, thank you very much for your useful thread. According to your guide, I compiled the forceBased files in foam-extend 4.0 with no problem and I tested a case in serial successfully. However, when I tried to run the case in parallel, I got a problem. I stopped the running halfway, but it could not restart from the latest time and I got a mpi error. When I tested the same case in serial, it had no problem like this. Did you meet the same problem like me before?
#3 | |
Yes, I have had problems with the IBM in parallel. I believe the issue occurs when the immersed boundary crosses the boundary between two processor domains. To solve this, if you're just doing a straight y-direction VIV, you can partition the domain using "simple", in a manner that the immersed boundary always stays within one domain. This is just my own past experience. |
#4 | |
Thomas Shi
However, when I took turbulence flow into consideration, a new error occured in immersed boundary condition of "U" file. I googled the error but did not get any solution. Have you ever used turbulence models in IBM? Have you ever met the same boundary condition error before? Your reply will be appreciated! |
Display Modes | |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
[ImmersedBoundary] Immersed Boundary Method | DoQuocVu | OpenFOAM Community Contributions | 11 | July 13, 2018 09:36 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
