Reading temperature in compressible k-omega SST
Hi all,
I'm trying to modify and build a version of k-omega SST (compressible) where I need to compute temperature gradients to evaluate and construct a new turbulent Prandtl number. I'm not sure how to get the turbulence solver to read in the temperature field to perform the processing. I tried adding T using: Code:
but the compilation fails saying no matching function call which leads me to RASModel.H where the T line doesn't exist. I could modify that as well but seems like a complicated thing. Is there a simpler way to read the temperature field into the solver? Thanks |
You can lookup T by
volScalarField Thelp = U.mesh().lookupObject<volScalarField>("T"); |
Hi Michael,
Thanks for this, I can confirm I was able to compile the solver with a slight modification: Code:
volScalarField THelp = U_.mesh().lookupObject<volScalarField>("T"); |
What you're getting is the temperature which is stored in the database. It is a constant reference. It means it cannot be modified. The temperature is updated only when the temperature equation is solved.
I understand. I fixed the issue and now it updates the Prt every iteration.
The issue came from the fact the updating was happening in a conditional loop which wasn't being entered into. Thanks for the help Michael! |
