Face Normal Vector Function Help
Old   October 28, 2019, 22:49
Question Face Normal Vector Function Help
WaterHammer1985 is on a distinguished road
I'm trying to write the face normal vectors for all face cells on a patch (ideally in the same order as the cell centers output from "postProcess -func wallCellCentres". I've scavenged code from old posts but I am stuck on getting the results to output. I'm running the functions from within the controlDict. I think at a minimum the "write" part of the fucntion isn't correct but I'm unsure how to fix. Any help would be greatly appreciated!
(I'm using v1906)
Try 1 (From Post #17 (Faces of a cell)
testFunc1
    functionObjectLibs ("libutilityFunctionObjects.so");
    enabled true;
    type coded;
    name  testFunc1;
    writeControl outputTime;
    codeExecute
        forAll(fluidRegions[0].cells(), cellI)
        const cell& faces = fluidRegions[0].cells()[cellI];
        forAll( faces, i ) // loop over all faces in cellID
                int k=faces[i];
                vector faceINormal = fluidRegions[0].Sf()[k] / fluidRegions[0].magSf()[k] ;
                vector faceICenter = fluidRegions[0].Cf()[k];
                Info << " k = " << k << " i = " << i << ", faceINormal = " << faceINormal << ", faceICenter = " << faceICenter << endl ;
Try 2 (From Posts #4/5 About extracting the normals to faces on a patch)
functions
computeNormals2
    enabled true;
    type coded;
    name  computeNormals2;
    code
        const surfaceVectorField& Sf = mesh.Sf();                   // Face area normal vectors
        const surfaceScalarField& magSf = mesh.magSf();             // Face areas
        const surfaceVectorField& N = Sf/magSf;                     // Face normal vectors
        Info << "maxN = " << max(N) <<endl;
        // Write
        N.write();
        N.boundaryField().write();
Output Log:
Using dynamicCode for functionObject testFunc1 at line -1 in "/p/work2/ps/profileTest/system/controlDict.functions.testFunc1"
Creating new library in "dynamicCode/testFunc1/platforms/linux64GccDPInt32Opt/lib/libtestFunc1_d54450d20b2d4857cb3f069b8ae4af60967656b2.so"
Invoking wmake libso /p/work2/ps/profileTest/dynamicCode/testFunc1
    dep: functionObjectTemplate.C
    Ctoo: functionObjectTemplate.C
    ld: /p/work2/ps/profileTest/dynamicCode/testFunc1/../platforms/linux64GccDPInt32Opt/lib/libtestFunc1_d54450d20b2d4857cb3f069b8ae4af60967656b2.so
--> FOAM Warning :
    From function virtual bool Foam::functionObjects::codedFunctionObject::read(const Foam::dictionary&)
    in file codedFunctionObject/codedFunctionObject.C at line 287
    Reading "/p/work2/ps/profileTest/system/controlDict.functions.computeNormals2"
    No critical "code" prefixed keywords found.
Please check the code documentation for more details.
Using dynamicCode for functionObject computeNormals2 at line -1 in "/p/work2/ps/profileTest/system/controlDict.functions.computeNormals2"
Creating new library in "dynamicCode/computeNormals2/platforms/linux64GccDPInt32Opt/lib/libcomputeNormals2_854fbc54de3816ba2f2d0fa40318ecadd3dad4cc.so"
Invoking wmake libso /p/work2/ps/profileTest/dynamicCode/computeNormals2
    ld: /p/work2/ps/profileTest/dynamicCode/computeNormals2/../platforms/linux64GccDPInt32Opt/lib/libcomputeNormals2_854fbc54de3816ba2f2d0fa40318ecadd3dad4cc.so
--> FOAM Warning :
    From function void Foam::timeControl::read(const Foam::dictionary&)
    in file db/functionObjects/timeControl/timeControl.C at line 94
Try 2 Error Log (doesn't crash simulation but doesn't write anything):
--> FOAM IOWarning :
    Found [v1612] 'functionObjectLibs' entry instead of 'libs' in dictionary "/p/work2/ps/profileTest/system/controlDict.functions.computeNormals2"
    This keyword is deemed to be 30 months old.
    ln: ./lnInclude
Note: When I use "code #{ }#" a warning shows that it should be "codeExecute #{ }#". If I use "codeExecute #{ }#" the simulation failes and gets an error:
Creating new library in "dynamicCode/testFunc1/platforms/linux64GccDPInt32Opt/lib/libtestFunc1_4e17b8c92ceee51ad09c0fa0f3b83d285367fb7d.so"
/p/home/openfoam/v1906/OpenFOAM-v1906/wmake/rules/General/transform:34: recipe for target 'Make/linux64GccDPInt32Opt/functionObjectTemplate.o' failed
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/testFunc1/platforms/linux64GccDPInt32Opt/lib/libtestFunc1_4e17b8c92ceee51ad09c0fa0f3b83d285367fb7d.so"
file: /p/work2/ps/profileTest/system/controlDict.functions.testFunc1
    From function void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const
    in file db/dynamicLibrary/codedBase/codedBase.C at line 231.
WaterHammer1985 is offline   Reply With Quote
Old   October 29, 2019, 16:34
I've also tried compiling it in the ~/src/functionObjects directory instead of within the controlDict, but I still have a wire crossed somewhere. To troubleshoot further, I've tried recreating a simple tutorial build (Ch. 3 - http://www.tfd.chalmers.se/~hani/kur...CFD_Report.pdf) which also fails.
From the error message, it appears to be looking for the #include "fieldExpression.H" file. That same header is in other functionObjects (i.e. vorticity) that appears to work without issue.
I've included the full error message, .H, .C, Make/files, Make/options below. Any help/hints would be greatly appreciated!
Error when running "wmake", executed in directory "~/openfoam/v1906/OpenFOAM-v1906/src/functionObjects/field/helicity":
~/openfoam/v1906/OpenFOAM-v1906/src/functionObjects/field/helicity> wmake
    ln: ./lnInclude
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3  -DNoRepository -ftemplate-depth=1024 -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/fieldExpression/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/fileFormats/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/surfMesh/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/meshTools/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/sampling/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/lagrangian/basic/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/lagrangian/distributionModels/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/thermophysicalModels/basic/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/transportModels -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/transportModels/compressible/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/TurbulenceModels/turbulenceModels/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/TurbulenceModels/incompressible/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/TurbulenceModels/compressible/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/transportModels/compressible/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/thermophysicalModels/basic/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/thermophysicalModels/solidThermo/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/thermophysicalModels/chemistryModel/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/thermophysicalModels/reactionThermo/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/thermophysicalModels/specie/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/fvAgglomerationMethods/pairPatchAgglomeration/lnInclude -IlnInclude -I. -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/p/home/openfoam/v1906/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude   -fPIC -c helicity.C -o /p/home/openfoam/v1906/OpenFOAM-v1906/build/linux64GccDPInt32Opt/src/functionObjects/field/helicity/helicity.o
In file included from helicity.C:28:0:
helicity.H:71:10: fatal error: fieldExpression.H: No such file or directory
compilation terminated.
/p/home/openfoam/v1906/OpenFOAM-v1906/wmake/rules/General/transform:34: recipe for target '/p/home/openfoam/v1906/OpenFOAM-v1906/build/linux64GccDPInt32Opt/src/functionObjects/field/helicity/helicity.o' failed
make: *** [/p/home/openfoam/v1906/OpenFOAM-v1906/build/linux64GccDPInt32Opt/src/functionObjects/field/helicity/helicity.o] Error 1
helicity.H
#ifndef functionObjects_helicity_H
#define functionObjects_helicity_H
namespace Foam
namespace functionObjects
                          Class vorticity Declaration
class helicity
    public fieldExpression
    // Private Member Functions
        //- Calculate the vorticity field and return true if successful
        virtual bool calc();
public:
    //- Runtime type information
    TypeName("helicity");
    // Constructors
        //- Construct from Time and dictionary
       helicity
            const word& name,
            const Time& runTime,
            const dictionary& dict
    //- Destructor
    virtual ~helicity();
} // End namespace functionObjects
} // End namespace Foam
#endif
helicity.C
#include "helicity.H"
#include "fvcCurl.H"
#include "addToRunTimeSelectionTable.H"
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
namespace Foam
    defineTypeNameAndDebug(helicity, 0);
        functionObject,
        helicity,
        dictionary
// * * * * * * * * * * * * * Private Member Functions  * * * * * * * * * * * //
bool Foam::functionObjects::helicity::calc()
    if (foundObject<volVectorField>(fieldName_))
        return store
            resultName_,
            fvc::curl(lookupObject<volVectorField>(fieldName_)) &
else
    return false;
return true;
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::functionObjects::helicity::helicity
    const word& name,
    fieldExpression(name, runTime, dict, "U")
    setResultName(typeName, fieldName_);
// * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
Foam::functionObjects::helicity::~helicity()
~/openfoam/v1906/OpenFOAM-v1906/src/functionObjects/field/helicity/Make/files:
helicity.C
LIB = $(FOAM_LIBBIN)/libfieldFunctionObjects
~/openfoam/v1906/OpenFOAM-v1906/src/functionObjects/field/helicity/Make/options:
EXE_INC = \
    -I$(LIB_SRC)/fieldExpression/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/fileFormats/lnInclude \
    -I$(LIB_SRC)/surfMesh/lnInclude \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/sampling/lnInclude \
    -I$(LIB_SRC)/lagrangian/basic/lnInclude \
    -I$(LIB_SRC)/lagrangian/distributionModels/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/transportModels/compressible/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/incompressible/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/compressible/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/solidThermo/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/chemistryModel/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \
    -I$(LIB_SRC)/fvAgglomerationMethods/pairPatchAgglomeration/lnInclude
LIB_LIBS = \
    -lfieldExpression \
    -lfiniteVolume \
    -lfileFormats \
    -lsurfMesh \
    -lmeshTools \
    -lsampling \
    -llagrangian \
    -ldistributionModels \
    -lfluidThermophysicalModels \
    -lsolidThermo \
    -lincompressibleTransportModels \
    -lturbulenceModels \
    -lcompressibleTransportModels \
    -lincompressibleTurbulenceModels \
    -lcompressibleTurbulenceModels \
    -lchemistryModel \
    -lreactionThermophysicalModels \
    -lpairPatchAgglomeration
functions, programming, surface normals
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 14:18
Need help setting up chtMultiRegion OskarT OpenFOAM Pre-Processing 1 September 25, 2019 15:51
[DesignModeler] Internal face normal direction Aidan.CFD ANSYS Meshing & Geometry 3 February 14, 2018 14:35
