calculating velocity and epsilon with the variation of height at the inlet bc |
December 26, 2019, 09:49 |
#1 | ||
Najmiddin
Rep Power: 7 |
Hello community,
The next question you are about to read is most probably asked somewhere else before, but I could not find the necessary answer and it might be because of my lack of knowledge in C++ So, I am trying to analyze a 2D rectangular geometry (adapted from a paper). Inlet boundary condition for velocity, k and epsilon is atmospheric boundary layer, as said in the paper. The already existing bc atmBoundaryLayer has different formulae for velocity, k and epsilon. Below is the original formulae used in the above mentioned boundary condition: Quote:
Equations I want to implement are as follows: Quote:
(patch().Cf().component(1) is the height. I saw the usage of it in some other boundary condition. Basically, my velocity changes with the height. I don't know how to declare what (patch().Cf().component(1) means in the code. I tried to include libraries I thought were necessary for(patch().Cf().component(1) to work. But after each wmake I consistently get the error of "patch is not declared in this scope". My second question is, as seen in the k and epsilon, k is velocity dependent, which is calculated with the U formula and epsilon is k dependent, and get an error of U and k not being declared. Below attached are codes and errors: .C file Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 2014-2016 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. \*---------------------------------------------------------------------------*/ #include "ABLformulized.H" #include "volFields.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // namespace Foam { // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // atmBoundaryLayer::atmBoundaryLayer() : flowDir_(Zero), //zDir_(Zero), kappa_(0), Cmu_(0), Uref_(0), //Zref_(0), z0_(0) //zGround_(0), //Ustar_(0) {} atmBoundaryLayer::atmBoundaryLayer(const vectorField& p, const dictionary& dict) : flowDir_(dict.lookup("flowDir")), //zDir_(dict.lookup("zDir")), //kappa_(dict.lookupOrDefault<scalar>("kappa", 0.41)), //Cmu_(dict.lookupOrDefault<scalar>("Cmu", 0.09)), kappa_(readScalar(dict.lookup("kappa"))), Cmu_(readScalar(dict.lookup("Cmu"))), Uref_(readScalar(dict.lookup("Uref"))), z0_(readScalar(dict.lookup("z0"))) //Zref_(readScalar(dict.lookup("Zref"))), //z0_("z0", dict, p.size()), //zGround_("zGround", dict, p.size()), //Ustar_(p.size()) //{ //if (mag(flowDir_) < SMALL || mag(zDir_) < SMALL) //{ //FatalErrorInFunction //<< "magnitude of n or z must be greater than zero" //<< abort(FatalError); //} // Ensure direction vectors are normalized //flowDir_ /= mag(flowDir_); //zDir_ /= mag(zDir_); //Ustar_ = kappa_*Uref_/(log((Zref_ + z0_)/z0_)); //} {} atmBoundaryLayer::atmBoundaryLayer ( const atmBoundaryLayer& ptf, const fvPatchFieldMapper& mapper ) : flowDir_(ptf.flowDir_), //zDir_(ptf.zDir_), kappa_(ptf.kappa_), Cmu_(ptf.Cmu_), Uref_(ptf.Uref_), z0_(ptf.z0_) //Zref_(ptf.Zref_), //z0_(ptf.z0_, mapper), //zGround_(ptf.zGround_, mapper), //Ustar_(ptf.Ustar_, mapper) {} atmBoundaryLayer::atmBoundaryLayer(const atmBoundaryLayer& blpvf) : flowDir_(blpvf.flowDir_), //zDir_(blpvf.zDir_), kappa_(blpvf.kappa_), Cmu_(blpvf.Cmu_), Uref_(blpvf.Uref_), //Zref_(blpvf.Zref_), z0_(blpvf.z0_) //zGround_(blpvf.zGround_), //Ustar_(blpvf.Ustar_) {} // * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * // //void atmBoundaryLayer::autoMap(const fvPatchFieldMapper& m) //{ //z0_.autoMap(m); //zGround_.autoMap(m); //Ustar_.autoMap(m); //} //void atmBoundaryLayer::rmap //( //const atmBoundaryLayer& blptf, //const labelList& addr //) //{ //z0_.rmap(blptf.z0_, addr); //zGround_.rmap(blptf.zGround_, addr); //Ustar_.rmap(blptf.Ustar_, addr); //} tmp<vectorField> atmBoundaryLayer::U(const vectorField& p) const { //vectorField n(patch().nf()); scalarField Un ( Uref_*pow(patch().Cf().component(1)/z0_,0.14) //(Ustar_/kappa_)*log(((zDir_ & p) - zGround_ + z0_)/z0_) ); return flowDir_*Un; } tmp<scalarField> atmBoundaryLayer::k(const vectorField& p) const { return 1.5*pow((U_*0.05),2); //sqr(Ustar_)/sqrt(Cmu_); } tmp<scalarField> atmBoundaryLayer::epsilon(const vectorField& p) const { //vectorField n(patch().nf()); return pow(Cmu_,0.75)*pow(k_,1.5)/(kappa_*patch().Cf().component(1)); //pow3(Ustar_)/(kappa_*((zDir_ & p) - zGround_ + z0_)); } void atmBoundaryLayer::write(Ostream& os) const { //z0_.writeEntry("z0", os) ; os.writeKeyword("flowDir") << flowDir_ << token::END_STATEMENT << nl; //os.writeKeyword("zDir") //<< zDir_ << token::END_STATEMENT << nl; os.writeKeyword("kappa") << kappa_ << token::END_STATEMENT << nl; os.writeKeyword("Cmu") << Cmu_ << token::END_STATEMENT << nl; os.writeKeyword("Uref") << Uref_ << token::END_STATEMENT << nl; os.writeKeyword("z0") << z0_ << token::END_STATEMENT << nl; //os.writeKeyword("Zref") //<< Zref_ << token::END_STATEMENT << nl; //zGround_.writeEntry("zGround", os) ; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // } // End namespace Foam // ************************************************************************* // and .H header file Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 2014-2016 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. Class Foam::atmBoundaryLayer Group grpRASBoundaryConditions grpInletBoundaryConditions Description This class provides functions to evaluate the velocity and turbulence distributions appropriate for atmospheric boundary layers (ABL). The profile is derived from the friction velocity, flow direction and "vertical" direction: \f[ U = \frac{U^*}{\kappa} ln\left(\frac{z - z_g + z_0}{z_0}\right) \f] \f[ k = \frac{(U^*)^2}{\sqrt{C_mu}} \f] \f[ \epsilon = \frac{(U^*)^3}{\kappa(z - z_g + z_0)} \f] where \vartable U^* | Friction velocity \kappa | von Karman's constant C_mu | Turbulence viscosity coefficient z | Vertical coordinate z_0 | Surface roughness height [m] z_g | Minimum z-coordinate [m] \endvartable and \f[ U^* = \kappa\frac{U_{ref}}{ln\left(\frac{Z_{ref} + z_0}{z_0}\right)} \f] where \vartable U_{ref} | Reference velocity at \f$Z_{ref}\f$ [m/s] Z_{ref} | Reference height [m] \endvartable Use in the atmBoundaryLayerInletVelocity, atmBoundaryLayerInletK and atmBoundaryLayerInletEpsilon boundary conditions. Reference: D.M. Hargreaves and N.G. Wright, "On the use of the k-epsilon model in commercial CFD software to model the neutral atmospheric boundary layer", Journal of Wind Engineering and Industrial Aerodynamics 95(2007), pp 355-369. Usage \table Property | Description | Required | Default flowDir | Flow direction | yes | zDir | Vertical direction | yes | kappa | von Karman's constant | no | 0.41 Cmu | Turbulence viscosity coefficient | no | 0.09 Uref | Reference velocity [m/s] | yes | Zref | Reference height [m] | yes | z0 | Surface roughness height [m] | yes | zGround | Minimum z-coordinate [m] | yes | \endtable Example of the boundary condition specification: \verbatim ground { type atmBoundaryLayerInletVelocity; flowDir (1 0 0); zDir (0 0 1); Uref 10.0; Zref 20.0; z0 uniform 0.1; zGround uniform 0.0; } \endverbatim Note D.M. Hargreaves and N.G. Wright recommend Gamma epsilon in the k-epsilon model should be changed from 1.3 to 1.11 for consistency. The roughness height (Er) is given by Er = 20 z0 following the same reference. SourceFiles atmBoundaryLayer.C \*---------------------------------------------------------------------------*/ #ifndef atmBoundaryLayer_H #define atmBoundaryLayer_H #include "fvPatchFields.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // namespace Foam { /*---------------------------------------------------------------------------*\ Class atmBoundaryLayer Declaration \*---------------------------------------------------------------------------*/ class atmBoundaryLayer { // Private data //- Flow direction vector flowDir_; //- Direction of the z-coordinate //vector zDir_; //- Von Karman constant scalarField kappa_; //- Turbulent viscosity coefficient scalarField Cmu_; //- Reference velocity scalarField Uref_; //- Surface roughness height //const scalar Zref_; //- Reference height scalarField z0_; //- Minimum coordinate value in z direction //scalarField zGround_; //- Friction velocity //scalarField Ustar_; public: // Constructors //- Construct null atmBoundaryLayer(); //- Construct from the coordinates field and dictionary atmBoundaryLayer(const vectorField& p, const dictionary&); //- Construct by mapping given // atmBoundaryLayer onto a new patch atmBoundaryLayer ( const atmBoundaryLayer&, const fvPatchFieldMapper& ); //- Construct as copy atmBoundaryLayer(const atmBoundaryLayer&); // Member functions // Access //- Return flow direction const vector& flowDir() const { return flowDir_; } //- Return z-direction //const vector& zDir() const //{ //return zDir_; //} //- Return friction velocity //const scalarField& Ustar() const //{ //return Ustar_; //} // Mapping functions //- Map (and resize as needed) from self given a mapping object void autoMap(const fvPatchFieldMapper&); //- Reverse map the given fvPatchField onto this fvPatchField void rmap(const atmBoundaryLayer&, const labelList&); // Evaluate functions //- Return the velocity distribution for the ATM tmp<vectorField> U(const vectorField& p) const; //- Return the turbulent kinetic energy distribution for the ATM tmp<scalarField> k(const vectorField& p) const; //- Return the turbulent dissipation rate distribution for the ATM tmp<scalarField> epsilon(const vectorField& p) const; //- Write void write(Ostream&) const; }; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // } // End namespace Foam // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #endif // ************************************************************************* // Errors: Code:
~/ABLformulized$ wmake wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file ABLformulizedEpsilon/ABLformulizedEpsilonFvPatchScalarField.C Making dependency list for source file ABLformulizedK/ABLformulizedKFvPatchScalarField.C Making dependency list for source file ABLformulizedInletVelocity/ABLformulizedInletVelocityFvPatchVectorField.C Making dependency list for source file ABLformulized/ABLformulized.C g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam4/src/finiteVolume/lnInclude -I/opt/openfoam4/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c ABLformulized/ABLformulized.C -o Make/linux64GccDPInt32Opt/ABLformulized/ABLformulized.o ABLformulized/ABLformulized.C: In member function ‘Foam::tmp<Foam::Field<Foam::Vector<double> > > Foam::atmBoundaryLayer::U(const vectorField&) const’: ABLformulized/ABLformulized.C:142:25: error: ‘patch’ was not declared in this scope Uref_*pow(patch().Cf().component(1)/z0_,0.14) ^ ABLformulized/ABLformulized.C: In member function ‘Foam::tmp<Foam::Field<double> > Foam::atmBoundaryLayer::k(const vectorField&) const’: ABLformulized/ABLformulized.C:151:21: error: ‘U_’ was not declared in this scope return 1.5*pow((U_*0.05),2); //sqr(Ustar_)/sqrt(Cmu_); ^ ABLformulized/ABLformulized.C: In member function ‘Foam::tmp<Foam::Field<double> > Foam::atmBoundaryLayer::epsilon(const vectorField&) const’: ABLformulized/ABLformulized.C:160:31: error: ‘k_’ was not declared in this scope return pow(Cmu_,0.75)*pow(k_,1.5)/(kappa_*patch().Cf().component(1)); //pow ^ ABLformulized/ABLformulized.C:160:53: error: ‘patch’ was not declared in this scope return pow(Cmu_,0.75)*pow(k_,1.5)/(kappa_*patch().Cf().component(1)); //pow ^ /opt/openfoam4/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt32Opt/ABLformulized/ABLformulized.o' failed make: *** [Make/linux64GccDPInt32Opt/ABLformulized/ABLformulized.o] Error 1 Thank you for reading and hoping for your quick responses. Last edited by najimaddin96; December 26, 2019 at 09:52. Reason: error in formula |
atmboundarylayerinlet |
Display Modes | |
Long output in terminal. | ssa_cfd | OpenFOAM Running, Solving & CFD | 1 | March 18, 2019 06:25 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 07:08 |
Inlet & Outlet Velocity BC issue | naiter | OpenFOAM | 3 | December 19, 2012 08:14 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 21:21 |
Velocity inlet K and Epsilon | Daniel Bruno | FLUENT | 6 | June 17, 2001 03:51 |
